JRP3
Hyperactive Member
That's possible but since the 3 will also be offered with a larger pack it will beat the Bolt by a large amount. I think the more aerodynamic 3 will beat the Bolt in highway range anyway even with the base pack.
Maybe it's because I only discuss in the EV context but I mostly see "LiPo" being used to describe LiFePo4. Lithium cobalt LiPo is pretty much nonexistent in the EV world (although there are those that use prismatic).It seems to me that most people using "LiPo" terminology are referring to lithium polymer gelled electrolyte, and ususlly cobalt based chemistries:
You bring up a good point. What do people mean when they say LiPo?While there is lab research in to polymer "plasticized" batteries, it appears that cells available on the market today billed as "LiPo" or "Li-Poly" are speaking primarily as a pouch format cell using a gelled electrolyte:
Further discussion that they aren't really a unique chemistry, but based on existing chemistries:
Thus you it would seem you can't really lump all Li-Poly together, but rather you'd need to compare specific chemistries.
For example, here are some comparisons of several different Li-ion chemistries:
Comparison of Types of Li-ion Cells
It demonstrates that power density, energy density, cost, cycle life, thermal stability, etc... are require a careful balance for a specific usage...
I would just stick to saying pouch cell if meaning just any pouch cell.
Yes, when I say prismatic, I usually mean a hard casing, but I know technically it includes pouch cells.Agreed. "Prismatic" is also typically used for that, although for precision's sake I might prefer if that meant a hard casing, and pouch a soft casing... but I'm not sure there is any such distinction.
If people missed the other thread, this is NOT the cooling architecture of the 100 packs.
Pics/Info: Inside the Tesla 100 kWh Battery Pack
That is perhaps even more interesting/exciting than if the X/MS100 pack would have the new features discussed in this thread. That would mean... that the new design will first surface with the model 3.
Who will be the first to wreck their Model 3 for wk057 to examine it?
Just because there is a patent does mean it will ever be used.
You are right of course. I should have prefaced my post with a qualifier like "potentially". But the patent is on the other hand not that groundbreaking or beyond the fray, but a rather practical, incremental improvement. So perhaps more likely to be used in real life, in contrast to (on the other hand of the spectrum) a patent for the first functional perpetuum mobile
It does make we wonder where the extra highway efficiency on the P100Ds comes from, though.
What extra efficiency? (There is ~16.6 more available kWh in the 100s than there is in the 90s, not 10 kWh like you would expect from the badge.)
Yeah, but that shouldn't have any effect on the MPGe rating...
Maybe the problem is that they are doing their calculations based on a 90 kWh pack when it isn't.
I don't think so. It's supposed to be miles driven over power from the wall - battery capacity shows up in the range, but shouldn't affect the efficiency number.
