I have several on some rental property and my home but they often go offline.I use a RainForest Automation Eagle Rainforest Automation | EAGLE-200™ Energy Gateway – Rainforest Automation net-consumption meter
The WiFi on these are not reliable. Mine is 1-foot away from the router and it still loses connectivity. So I now only use the LAN connection. Since changing that, it has work reliably for a continuous few weeks -- for me.I have several on some rental property and my home but they often go offline.
I use TP-Link HS110 for per-appliance monitoring: HS110 | Kasa Smart Wi-Fi Plug with Energy Monitoring | TP-Link which allows for remote monitoring, scheduling, and compatible with OhmConnect.Yes I have one of those too for accurate reporting of overall NET consumption, however thats all its good for. If you want per branch reporting, or down to appliance level detail, then it does't cut it.
Well, I'd still like to see @Brovane reply about what he thinks about the sense.I use TP-Link HS110 for per-appliance monitoring: HS110 | Kasa Smart Wi-Fi Plug with Energy Monitoring | TP-Link which allows for remote monitoring, scheduling, and compatible with OhmConnect.
It's annoying my system is all spread out, so I can understand why the Sense would be better.
Still waiting for Tesla to put out some stock so I can install. I've already queued for step-2 SGIP rebate (though not via Tesla).Out of interest, I assume you have a powerwall? If so did you do it with an SGIP rebate, and how are you planning to resolve the conflict that the SGIP discharge requirements will bring with messing up your ohmconnect baseline?
I'm interested in what you think of the Sense and its abilities to track each electrical device? A friend of mine wanted to buy one, but he's also seen the amount of data that my Brultech GEM generates, and is on the fence with the easy install of the Sense versus the nightmare that a Brultech GEM can be to install...
After I ripped out my GEM (pre powerwall install), it took me a whole day to re-install it again since its even more complex to wire it now to multiple areas and work out the configuration to have it all configured correctly. Totally worth the effort though as the amount of data it generates is great if you are a data junkie.
@Brovane, are you able to send Private messages? Not sure if this forum supports that or not, if its something that you can only do after X posts.
My RFA just went offline past Friday even when it was undisturbed for weeks solely on ethernet. Had to power-cycle it to bring it back. Now it's going to sit behind a TP-Link HS105 to manage it.I have several on some rental property and my home but they often go offline.
