New rear appliqué?
Discussion in 'Model S: Interior & Exterior' started by Jgdixon, Aug 8, 2015.
  1. Jgdixon
    Jgdixon Active Member
    Burlington, Ontario, Canada
    Someone just posted this on Facebook. It's the new rear appliqué redesigned to eliminate the moisture problem in the clear lenses in the reverse lights. The letters are more prominent. Supposedly all cars made now will have this.Can be retrofitted apparently.
  2. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    I'd love to receive this retrofit FREE, as my lenses still fog up. They used to fill up with dust as well, but the service center seems to have corrected that issue. Actually on 2nd thought, never mind. I'm afraid they'll make it worse.
  3. FLDarren
    FLDarren Member
    Seminole, Fl.
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    This photo does not show the ends, which are the source of the problem, so it's hard to determine what changes were made other then raising the letters a bit more. Are the back up lights obscured? How are they handled?
    The new design will make it easier for us to cut out the letters for our lighted appliqué, shown in FLDarren's post.
  5. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    The ends (from what I’ve been told - and photos I’ve seen) have no outer lens, so they have either figured out a way to waterproof the inner lens, or it already is. The fogging issue was between the outer lens and the inner lense.
  6. AmpedRealtor
    Phoenix, AZ
    I heard reports of this new appliqué being field tested by Jerome on one of his cars 8-12 months ago. Wow, it sure took a long time to get the modification into production...
  7. Zextraterrestrial
    Humboldt/Los Altos
    I was wondering why the hell they had an outer lens in the first place. could have been designed much better.
  8. artsci
    artsci Sponsor
    Timonium, Maryland
    Elimination of the lens doesn't eliminate the moisture, it just hides it.
  9. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    I don't quite understand what you are saying. My issue (at least) was moisture trapped between the appliqué (outer) and the inner lens. If they have indeed removed the outer lens altogether, then the only place the moisture would be hiding is in an evaporated form ;)
  10. Sosius
    Sosius a.k.a. Uptown Frunk
    Gulf Coast
    #10 Sosius, Aug 10, 2015
    Ooh, I want! I haven't complained about my foggy lenses, because I assumed nothing could be done to fix it. Guess I have to contact service and see if I can get on the list!
  11. mknox
    mknox Well-Known Member
    Toronto, ON
    My rear appliqué has been off a couple of times for backup light fogging and once to replace my rearview camera that crapped out. I still have fogging in the backup lights and I even get a fair bit of fogging/moisture inside the tail lights, mostly the left one. Each time, they told me that they had re-applied it with some new and improved technique.
  12. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    If this is truly a fix it should almost just be a recall as nearly every Tesla owner I've spoken to has fogging in the tail-lamps - some more than others.
  13. AmpedRealtor
    Phoenix, AZ
    ^^ this
    Tesla should make this a universal service bulletin and apply it to all vehicles.
  14. mknox
    Toronto, ON
    Tesla doesn't use the "R" word. They do "proactive replacements" :biggrin:
  15. artsci
    artsci Sponsor
    Timonium, Maryland
    During the lighted appliqué group install at delanman's house a month or two ago we developed a solution that works quite well. The extreme edges of the appliqué pull away from the tail light just a bit, allowing moisture to enter. When we reinstalled the appliqués we added a dab of clear silicone sealant to each end then taped them down for 24 hours. That appears to work. I've not had moisture in mine since.
    - - - Updated - - -
    That's why I wanted to see a photo of the ends of the new version. If there's no clear lens, the moisture won't show, but then the back up lights won't show either. So how they redesigned the ends is what matters most, not what they did with the raised TESLA letters.
  16. mknox
    Toronto, ON
    The pulling away at the ends has been my observation as well. The silicone trick sounds like a good solution.
  17. artsci
    artsci Sponsor
    Timonium, Maryland
    I think I have an answer to my own question about the design of the ends of the new Model S appliqué. My SC told me the new appliqué would be paired with a redesign of the tail lights. Having just seen the photo below of the Model X rear end, I now think I know the solution: the new appliqué will not extend over the tail lights and the back up lights. Easy solution to the moisture problem. Maybe in fact the Model S and Model X will share the same appliqué and tail lights. Seems quite plausible.
  18. JPP
    JPP Active Member
    SF Bay Area, CA
  19. artsci
    artsci Sponsor
    Timonium, Maryland
    According to my SC this has been through several iterations, including ones that were intended to prevent the ends from lifting off and allowing moisture in. The Model X solution seems the best way to go. If one looks carefully at the Model X appliqué the raised and squared off letters are there.
  20. mknox
    Toronto, ON
    I guess that doesn't bode well for retrofits on existing cars. Even if Tesla did agree to replace both lights and the chrome strip, the car body may end up being tweaked to accept the new tail light assemblies.
