stopcrazypp
- Dec 8, 2007
- 9,875
- 4,801
So I keep seeing people throw around hard numbers on how many cells are in the packs... My understanding was that was a very good guess. Did someone actually get the chance to rip apart either of the packs to confirm these numbers? If so, then why didn't they also take the time to pull the real measurements off the cells (volts and amps)?
Cell count has been verified by ripping apart a salvaged pack and counting the number of modules and cells (previously there was also evidence from an NHTSA crash test document, although without as clear pictures):
http://www.teslamotorsclub.com/showthread.php/31831-Battery-interior-and-Repair-of-Model-S/page2
The OP of that thread still has the project ongoing and haven't responded to some of the posts (including one from JRP3 asking to verify the cell capacity).
However, 3.1Ah is virtually impossible. It would need a 3.86V nominal voltage and none of the Panasonic chemistries operate at that high a voltage.
The closest is the "3.4Ah" (actually 3.35Ah if referencing the NCR18650B datasheet). This would result in 3.6V*3.35Ah*7104 = 85.674kWh
http://industrial.panasonic.com/www-data/pdf2/ACI4000/ACI4000CE54.pdf
