New Roadster Goodies for 2014
jeremyz
257
94
I'm not sure of the Roadster motor dimensions. From this image Tesla Roadster #55 and google telling me that the vertical part of PowerBuilt 1500 Pound Engine Leveler is 7.2", I measured the main portion of the roadster motor as 10" in diameter. I went to the Tesla store and measured the Model S drivetrain. It's slighthly less than 31" wide including the plumbing for the liquid cooling; The Model S motor is 11.5" in diameter. Taking those dimensions and this image, http://www.technologyreview.com/sites/default/files/legacy/0908_hack_x600.jpg, I roughly mocked up what the Model S drivetrain would look like in the Roadster after rotating it 90 degrees. From this very rough process, it looks like the Model S drivetrain could fit in the Roadster. The Model S drivetrain is quite small compared to the Roadster's because it's liquid cooled, they used much newer/better IGBT's in their inverter and it wasn't Tesla's first rodeo.
JRP3
Hyperactive Member
Aug 20, 2007
19,444
42,611
Central New York
Looks as if the suspension mounts to the Roadster frame, so they would not be affected. All you'd need to do is cut the axle shafts and weld the Model S motor side to the Roadster hub side. Making new motor mounts would be fairly easy.
JRP3
Hyperactive Member
Aug 20, 2007
19,444
42,611
Central New York
Well then the engineering has already been done by Tesla, so contrary to my earlier statements it may be that something will be offered from the factory at some point.
TEG
Teslafanatic
Aug 20, 2006
21,719
8,690
Regen and integration with ABS system need to be considered as well.
Roadster PEM acts as charger too, whereas MS uses separate charger modules. If MS PEM was used, one would need to find a way to get MS charger to talk to Roadster pack too...
Anyways, I too heard rumors that such a beast existed in some form at some point.
strider
3,516
759
NE Oklahoma
Nice dream, but it won't be reality. Model 3 won't out-accelerate Roadster, for instance.
Thought I would come over here and stir the pot in light of the P85D launch tonight. All I can say is that since a 4,600lb Model S can now out-accelerate the Roadster, the PXXD Model 3 (being lighter with the same amount of power) will simply bury it. :)
FANGO
1,276
376
400 Mile Pack (Was New Roadster Goodies for 2014)
I want a lighter roadster :/. Just let me buy half of a 400mi pack, guys. Ill split it with someone. It'll be all good.
wiztecy
2,905
563
I like more range, with more Range means less stress on the overall pack, less heat built up from use, and longer life overall. I'm happy the way I have my Roadster dialed in for handling, although quicker would be great, its still quick enough for me and still is thrilling as the first day I drove it.
The next generation Roadster will most likely have all our wants and needs fulfilled and then some.
richkae
VIN587
Jan 15, 2008
1,917
29
I don't want a faster Roadster... I want one with >30 minutes endurance on a race track.
+1
I'd be happy with 20 minutes.
( Note that this has nothing to do with the battery. It's all about the motor heating up )
wiztecy
2,905
563
Less weight also means less stress on the pack
Not really, when the pack has more capacity there's less stress on each individual cell. Also this means less time of the pack being pulled down below 30% SOC and less need to do full 100% Range mode charges. Its the same in essence of the Nissan Leaf vs. the Roadster at its current range. Leaf owners have to do full 100% charges and always drain their packs down to a very low, sometimes single digit SOC values.
Heat will be allot less for each cell since less amps has to be pulled, the SOC will also reside above 50% longer since the pack has more range/capacity. Ever see how fast your pack heats up below 50% SOC? Also pulling hard from the pack below 50% is not that good for the cells.
