I monitor the power drawn at the point where my UMC2 plugs in. During the last two charging sessions the KWH's used were the same at the monitor point as the new Charging Stats. Could be off by +/- 1KWH because neither had decimal point precision. The Smartphone app also displays the KWH added for the last charging session in the area where you can adjust the amperage. Since it appears the new Charging Stats is closely reflecting the power drawn from the wall, I hope the other reading is the amount of energy added to the traction battery. If true, the difference between the two would reflect the approx overhead involved during the last charging session (ie.. battery heating, energy required by the car to allow charging, etc.) If the traction battery was cold soaked to a point where several KWH would be required to heat the battery during a charging session, the two KWH values could be different. Maybe someone who lives in a cold area of the country could report the two values after a charging session with a cold traction battery? If this person also had SMT to report the cell temps, that would be plus!
