New squeak, new roll/rattle, worrisome gap...
Discussion in 'Roadster 2008-2012' started by xytor, Mar 2, 2015.
Tags:
  1. xytor
    xytor Roadster #221
    Seattle
    Hi,
    Over the weekend I accidentally took some pretty violent bumps while accelerating. I think I may have even caught a bit of air... :eek:
    Anyway, I've noticed a new squeak that is pretty constant when the car is moving, something is rolling around when I turn, and there's a gap on the bottom plate... (pictured). Although I don't know if the gap is new. Is it supposed to be like that?
    What do y'all think?
  2. spaceballs
    spaceballs Member
    Sammamish
    #2 spaceballs, Mar 2, 2015
    If you have the same gap other side, if yes, then I personally not worry, unless you see other damage.
    If you dont have the same gap on the other side, and it's only the undertray part then your likely fine.
  3. xytor
    xytor Roadster #221
    Seattle
    There is the same gap on the other side. I was just hoping somebody here could look under their own roadster 1.5 and see if it's there :)
  4. xytor
    xytor Roadster #221
    Seattle
    Mystery number 2 solved:
    The rolling thing was a bunch of coins that I literally shook out of my passenger, haha!
  5. m0rph
    m0rph Member
    Belgium
    LOL :)
  6. AudubonB
    AudubonB One can NOT induce accuracy with precision!
    ....and that's what you call a High Roller.
  7. xytor
    xytor Roadster #221
    Seattle
    Mystery number 1 is a squeaky suspension above the rear left wheel... I guess that's something that can happen in all cars and is most likely harmless.
    And the gap is perfectly normal, according to some knowledgeable folks!
    Still have something else rolling around though...
  8. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I has this issue and replaced my rear bushings. It took about 2 hours per wheel for me to do. All has been quiet for a year. A spray lubricant can also help but only for for a week or two.
  9. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I have that squeak on both sides. Someday I will do something about it...
  10. xytor
    xytor Roadster #221
    Seattle
    Yea there are so many other squeaks, I should just stop worrying and enjoy the car.
