  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
New Supercharging Taper Protecting Battery?
It seems commonly accepted that frequent supercharging increases battery degradation. With the recent software updates seemingly increasing the taper of charge rates downward is there any thought this lessens the degradation impact of supercharging? If so, any evidence to support this?
On my chart from Teslafi , my degradation has gone straight down since sw update. I just went on trip this weekend, supercharging takes a lot longer and starts a lot lower. I have a record of every supercharging for 3 years. I used to start at 115 to 125kw, and charge up in 30 minutes. Now I'm lucky to start at 80 go down to 30kw fast and take hour or more. Everyone says it depends on state of charge when we plug in? I go up and down 95 a lot, I really notice the slowness now.
I read this weekend there was a class action suit about this situation since last update. Google it.
I don't think anyone knows for certain what is going on or why. Many have observed shortened range and longer Supercharging sessions (slower rates and sharper taper) shortly after a Tesla MS battery fire in China and Belgium in May of 2019. Tesla mentioned faster charging times with V2 stalls going from 120kW to 150kW, but many 85kW pack owners noticed both a lower voltage maximum capacity, lower Supercharging speeds, and the taper starts earlier relative to before the software update.
Some have speculated that Tesla feared potential battery fires and decided to restrict the battery capacity and charging rate, while some think Tesla fears being liable for battery replacements under warranty. I'd like to know the truth as it is discovered but I definitely feel out of the loop.
BerTX
3,508
3,664
Texas/Washington
Do you have a reference regarding a class action suit about charging rate? The only one I have heard of specifically targets the reduction in battery capacity/range. It does not include reduced charging rate.
BerTX
3,508
3,664
Texas/Washington
Are you sure? I thought reduction in battery charge rate was part of the claims in the class action suit.
No, I'm not sure. There is so much back-and-forth on this I can't keep up. I thought it was thought to be two different issues with two different battery chemistries, so they are not related. Maybe the heavy-handed style of the "solutions" is common enough to lump them together.
But to answer your question, no I'm not sure.
cpa
3,588
5,238
Central Valley
Find the complaint and read it. It is online. I believe there are nineteen claims listed in it. Significantly reduced Supercharging speeds is among the causes for at least one of the claims against Tesla.
There is another LONG thread on the issue of Tesla throttling the max available SC rate for owners of S70/75 and S90 vehicles in order to protect the longevity of their batteries (a "feature"):
If you fast charge, Tesla will permanently throttle charging
I have a S75
The 350V 75 variants, will be permanently voltage throttled over time based on the amount of energy supplied to the pack via DC fast charging on a specific counter in the software. The “feature” typically activates at approximately 2500 kWh of DC fast charging applied via Supercharging or other alternatives. It then continues until reaching a maximum derated state and appears to currently drop no further.
Your peak charge at all Superchargers on a maximum derated pack will not exceed 80-82 kW reaching this maximum between 40 and 50% SoC and will then taper very quickly beyond 60%.
