MrBadger
Badger out
Rub it in don't you that iPhone 6 was the cutoff point of iOS 12.5My iPhone 6s is on iOS 14.7.1, and is fine. My ancient iPad is on iOS 10.3.3, and nogo.
Glad your 6s doesn't suffer this limitation.
Yes it does. Swipe right from home page, press Edit, and then add Tesla. This also worked for me on normal app screens. There are two size options that show range, etc.The new iPhone app doesn’t have a widget… fail!
That sounds like your car options are set incorrectly? (By Tesla)We've got a '21 M3, MSM exterior / white interior - in the [new] app the exterior is correct, but the interior shows as black (with wood trim), which is the same as It was in the pre-4.0 version.
So no improvement for us (with a recent Model 3).
It’s possible, but I don’t recall the easiest way to do it.So that's upstream, on the server side? Is there anyway to see those settings / confirm the setting, from the car? I see above @davezforce has what looks like a config file/plist of some sort.
I'm a software engineer so you can hit me up with as much technical voodoo as you want
Tesla API? Gen a token, get the car config?
That’s interesting because I don’t see it on my widget list following your instructions (iPhone 12 pro max with latest fw)Yes it does. Swipe right from home page, press Edit, and then add Tesla. This also worked for me on normal app screens. There are two size options that show range, etc.
I think this is the actual root of the problem!!!Or is our older cars just configured wrong.
Update: I had to delete and reinstall the Tesla app to be able to see the widget.That’s interesting because I don’t see it on my widget list following your instructions (iPhone 12 pro max with latest fw)
I appreciate the update while also wanting to provide feedback for the next update. I'm sure the UX team appreciates the feedback.
You can divide watts by amps to get volts, but yeah, it would be nice if it was just displayed for you.Also it looks like during charging, the charge voltage is no longer displayed. Just SoC, time remaining, Amps and kW. Was helpful at public L2 chargers to determine if they were 208V, 240V, or 277V (if 277V public chargers exist around here, I've never seen one.)
Sorry - I didn't realize there was a big difference between a 6 and a 6s.
I like being able to see the voltage to see if there's excessive voltage drop under load on an unfamiliar outlet. But it's a small thing, you can just check the instrument panel inside the car after it ramps up, and usually if there's a problem the car will limit amps on its own or just shut it off, so not a safety issue. But I also wish every car allowed you to display every parameter monitored by the car in real-time, so, I like a lot of info. Some people just want the needle to point at the middle of the gauge.You can divide watts by amps to get volts, but yeah, it would be nice if it was just displayed for you.
I'm sure the UX team appreciates the feedback too...by reporting the feedback to them. They aren't checking this forum for your ramblings.
How do you see supercharging history, I can’t find it in the new iOS appYou also can just go into the app store on your device. Click on your account where it shows you the of your app update history and if any updates are available. If you don't see it queued, you can just do a pull down on the screen, which will force your phone to go check the app store for all the latest versions. I did that on my devices and up popped several apps with updates available, including the Tesla app.
I'm pretty much in the 'ok, big deal' camp on the update. The only new feature that I see, although you have to dig to find it, is the ability to see your full supercharging history. That includes if your someone like me that still have free unlimited supercharging on their car. I can see my history all the way back to Jan 2017. Doesn't appear to have any of my history from the second half of 2016 (purchased my MS90D end of June 2016).
Mine said it updated in the Play store and the app ver is 3.10.14 but I do not see any difference. I logged out ans logged back in. App looks the same to me.Android version hasn't been released yet. Appears only the Apple version is available today. Android should follow shortly I would assume.
