New Tesla CHAdeMO Adapter
Discussion in 'Tesla Parts for Sale' started by FalconXGuy, Jan 16, 2017.
  1. FalconXGuy
    FalconXGuy New Member
    antioch,ca
    20170113_094504.jpg Purchased a Tesla CHAmeDO Adapter when I purchased our Model X last April. Brand new in box never opened.
    Asking $ 425.00 plus $ 20.00 shipping.
  2. Zroiron
    Zroiron Poodle Pack Leader
    Las Vegas
    Why are you parting with it?
  3. FalconXGuy
    antioch,ca
    Haven't found any need to use it as live in the bay area and when travel there are plenty of
    superchargers on my travel routes.
  4. rhino
    rhino Member
    What exactly does this do? Seen it before but don't understand when it's needed?
  5. rocketshipp85
    rocketshipp85 Member
    MD
    Will you take $400 shipped.
  6. Ulmo
    Ulmo Active Member
    Vienna Woods, Aptos, California
    Allows you to use Chademo charging stations, such as at EVGO, like the Leaf do. Look on Plugshare and check the "Chademo" only filter, and allow paid locations, zoom out enough, and you will see lots of Chademo all over the place, if not in your area specifically.
    For EVGO, the speed varies between 28kW and 45kW depending on state of charge and charging station. Most are 100 amp and some are 125 amp. Not as fast as a SuperCharger (usually), but much faster than a Level 2 (usually). Only a 80 amp dual charger or 72 amp Tesla could rival this if everything is working right at the lower end of the Chademo scale, but mostly the Chademo is 2x to 4x as fast as home charging, depending on conditions. Often, it's the fastest available way to charge, depending on locations.
  7. GWord
    GWord Member
    Houston, TX
    CHAdeMO is a type of fast charger, similar to Tesla's Supercharger system. This allows your Tesla to utilize these types of connections. CHAdeMO stations tend to be clustered in and around major urban areas so the usefulness of the adapter varies.
    Edit: never mind. Ulmo has it covered above!
  8. FalconXGuy
    antioch,ca
    Thanks to everyone both for the questions as well as the detailed explanation of what a CHAmeDo Adapter is used for,
    item is now SOLD.
  9. Ulmo
    Ulmo Active Member
    100 amp Chademo is slow:
    20kW is about the same as a dual charger (80 amp) Model S or 72 amp charger Tesla Model S/X.
  10. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    It should speed up a little bit as the voltage comes up.
  11. David99
    David99 Active Member
    Brea, Orange County
    The adapter is limited to 125 Amp. The most you can theoretically get is aprox 50 kW but realistically it's around 45 kW which is still pretty decent. This adapter is very useful for trips outside the Supercharger network.
  12. JasonA-EV
    JasonA-EV Member
    Los Angeles,CA
    no, what you show is not CHAdeMO but dual units on 277v aka 20kw.
    CHAdeMO would be giving you twice or 40kw avg and say it on the screen. The taper goes up higher also.
  13. Ulmo
    Ulmo Active Member
    Something about the state of charge being at 4% state of charge had something to do with it I bet. Both the BMS throttling charge speed and the voltage needed to charge at that SOC. I was not using AC.
  14. xbox4me62
    xbox4me62 Member
    SF bay area
    That makes sense actually. Once your SOC goes up a bit i'm pretty sure the voltage can increase and you'll be charging at ~145 mi/hr. Which is not bad.
  15. dhcp
    dhcp Member
    San Mateo, CA
    I keep one of these in my trunk for emegencies, never know and they sell easily if you decide to get rid of it down the road.
  16. playoutside
    playoutside Member
    Seattle, WA
    hey peeps, I'm selling one for $390 if interested. I just posted an ad.
