NEW Tesla HPWC High Power Wall Connector Charger Level 2 cable Brand new Tesla high power wall connector Model PN 1008488-99-C with No tax DESCRIPTION ? You are bidding on a Brand new in box Tesla high power wall connector. (HPWC) ? The Tesla Wall Connector is a hardwired charging station designed for 208-240 volt power supplies. ? Operating current (up to 80 amps) will be configured by the installing electrician, allowing the unit to be customized to almost any power source. ? For the fastest charge rate, install the Wall Connector with an 80 amp or 100 amp circuit breaker. ? The unit is also capable of being installed on 15, 20, 30, 40, or 50 amp circuit breakers. ? Charge rates will vary depending on circuit breaker rating. Connector cable is 25 feet ?The Wall Connector is the fastest and easiest home charging solution available for Model S. ?It works with any Model S and can provide a charge rate of up to 58 miles of range per hour for vehicles equipped with Dual Chargers. ?It works with any Model S and can provide a charge rate of up to 29 miles of range per hour for vehicles equipped with Single Chargers ?Installation of the Wall Connector should be completed by a licensed electrician. ?A detailed installation guide is available online: http://www.teslamotors.com/sites/default/files/downloads/charging_wall_connector.pdf https://my.teslamotors.com/sites/default/files/blog_attachments/wall_connector_install_guide_northamerica.pdf List Date: 7/25/2015 For more info, click here to view the original listing: NEW Tesla HPWC High Power Wall Connector Charger Level 2 cable -------------------------------------- SOLD --------------------------------------
