I have a PMY on order with an EDD of 27 July to 31 Aug. Moving from a 2020 LR AWD Y, I have decided to avoid all the drama of trying to live with the 21" Uberturbine tires/wheels here in Illinois aka Land of Pothole's so I opted to replace them with a smaller tire/wheel package from TSpotLine. Initially, I was looking at the 19" squared package but then they started offering an 18" package. After doing weeks of research I decided for my needs the 18s made more sense. So with their Memorial Day sale about to end, I pulled the trigger yesterday and ordered them. This is what I ordered for my MSM PMY:
These are their wheels that are similar in appearance to the first version 21" factory Turbine wheel on a Model S.
Details:
The 4.8" tall sidewall also reduces the likelihood of 'curbing' your wheels, as commonly occurs on lower-profile / larger diameter setups.
I'm told I should recover some of the range delta from the 330 mile LR AWD Y and at almost 16 pounds lighter than the 21s who knows maybe performance will be better.
I couldn't pass up their Memorial Day Sale, and I already have FedEx tracking numbers. While they wait for my PMY to arrive I will practice applying Ceramic Coating on them.
I will conduct BEFORE and AFTER range and performance tests once I get my car.
Cheers
Details:
- 4x 18x8.5" Wheels
- 4x 245/50-18 Tires
- 4x T Sportline Wheel Center Caps
- 4x Tesla Factory Tire Pressure Monitor Sensor (TPMS)
- No additional hardware is required. Use your factory lug nuts!
- Size: 18x8.5"
- Offset: +35
- Bolt Pattern (PCD): 5x114.3
- Center Bore: 64.1
- Construction: Flow Forged
- Weight: 23.6 lbs
- Load Rating: 750 kg/1,653 lbs
- Tire Size: 245/50-18
- Colors: Brilliant Silver, Space Gray, Gloss Black, and Satin Black.
- Tires (subject to availability): Michelin Pilot Sport All-Season 4
Cheers
