I think Tesla changed the UMC downward to 32A for a few reasons, the first was in response to electrical code (Ontario, specifically) so Canadians received the "great news" first and were having 40A UMC "ripped from their hands".. not really.
Then there was also overheating issues, not necessarily with the UMC or its handle itself but with house wiring catching fire, receptacles frying, or house wiring melting, etc.. Which doesn't look good for a startup company having things burn to the ground is bad press... "Electrical Charging in Your Garage is More Dangerous Than Possibility of Gas Fumes Exploding"... or whatever headlines, wanting to avoid those.
The reason why receptacles overheated was because of .. drum roll.. poor parts and electrical wiring practices that are within a grey area of code. In other words, the very things that Ontario tries to protect by not allowing 100% full draw on 40A circuit for EV charging. People smacking in 50A breakers is a bad thing to get the UMC up to max thrust when wiring is at best 40A * 0.8 capable of sustained use (code). Dumb users, house fire, but makes Tesla looks bad. EVEN though there's a facility in the car (console) to dial down power draw... requires a person to do that... default is 40A. One way to limit the heat / fire problem is limit the draw, thanks 32A UMC was born! Maybe another way of accomplishing the same thing would have been to software limit the car side the draw to max 32A for anything plugged into the port that is reporting 40A capability.
Shave parts power handling capacity (UMC and car) and shave weight and dollars so prices of things improve.
If you have the stronger 72A onboard charger then the UMC is not enough in any capacity to fill those boots and we're looking at HPWC or equiv ... which means special wiring must be installed. As a job, the electricians cannot ignore the load asked and will install the right breaker, the right wire, etc.. and less fire potential. However, that HPWC can get hot! (Another story).
For me, old car.. got the 80A on-board dual chargers... 40A UMC.. and 80A old fashioned HPWC. UMC is only used mobile... and I typically have a 6-20 head on for everyday but swap it off for 14-50 every two months on some trip... This UMC has had no issues with heat on any part of the connections it has between receptacle and car.
I'm happy to have the 40A setup for UMC and am of the belief every Amp counts when you're on the road and having to use the UMC. Especially when using the car pre-heating modes that suck overhead kW just for heating battery pack and interior.. The allocation (remainder) of the power available for battery charging appreciates that extra 8A of the old UMC.
Typically, though.. on a daily basis it doesn't matter. 6-20 all day at work is enough for my commute and a weekly Supercharge handles weekend run-arounds... I hardly charge at home anymore so that HPWC is mostly gathering dust. It cost me about $7000 to upgrade my house to have a HPWC... 4 years ago was needed. But not today, would never recommend it unless you're using your house a "home base" for a lot of driving radiating out from there. For me, today... a 32A UMC at home would do fine if that were all I had and I would keep it mobile - in the car normally.
