Looking for some help here guys.
I got the new wall connector and I was going to install it along with a separate NEMA 14-50 as we will have multiple Tesla vehicles. But now I'm thinking that maybe I should just get 2 wall connectors?
I don't like this "load sharing" thing on one breaker. Wouldn't the charging speed be significantly less if 2 wall connectors are sharing one breaker? So perhaps install them on 2 separate breakers?
I'm sure FlasherZ is answering your question right now with more accuracy than I am, but, here's my understanding: if you have more than 100A available from a load perspective on your main panel, then, you have to consider HOW MUCH you have. You can total whatever that is up, and then decide how much you want for each HPWC. Once you figure that out, you can install circuitry, conduit, and breakers, to match that, and set the settings of the HPWC's that way.
For instance, if you have 150A available to use in your main panel, then one HPWC could have a 100A circuit set for 80A draw and another could have a 50A circuit set for 40A draw. They would not communicate with each other, and to charge faster, you'd have to put the car on the 100A circuit (80A draw). You would not need to buy an additional slavable unit.
Or, if you have 200A available, you set up both for 80A draw (100A circuit breakers each). You would not need to buy an additional slavable unit. This is ideal, since you wouldn't have to figure out which car to charge faster, as both would get maximum charge. Typically, affordability of more amps available goes down. I'd be pretty surprised if a high number of people said "oh yeah, 200A, no problem! That's sitting unused in my panel right now!".
Or, if you have (only) 100A (or less) available, you then would WANT to buy an additional slavable unit, take out the old model and put it up for sale once you're done with it, and install the master/slaves both for 80A draw off 100A circuits, each with their own 100A breaker and conduit, installed as per discussed here (or less if less is available).
Edit: Uhoh. I misread your question. I think those plug in UMC things are dangerous, so I an prejudiced against those, and that guided my misreading. But, here's my newfound interpretation: just get two (of these new slavable) HPWC's, and figure out how to properly install them for your available amps. Most people don't have two hour commutes and only 2 hours of sleep, so in the overnight even with both vehicles plugged in, they should charge up pretty nicely with only a modicum of main panel expense (generally speaking). In your situation, these new HPWC's are fantastic, if you have modest needs and modest main panel availability.
I really like the future-proofing aspect of these units in a home garage setup: you could set up 3 new HPWC's each with their own 100A wiring, circuitry, etc., back to a dedicated breaker panel capable of handling 400A (for future expansion), with 3 100A breakers to those HPWC's, all on this master-slave bus, set for 100A circuits on all of them (80A draw), and the 400A panel would only be fed with a 100A circuit from the main panel. In the future, if you get a 4th Tesla car and HPWC and want to charge faster, you can upgrade your main panel, output maybe 200A with its own dedicated breaker to the 400A subpanel, and then the only other change you have to make is splitting the master-slave bus in half, with two HPWC's on one half and two HPWC's on the other half, each set drawing up to a maximum of 100A (each set would have one master and one slave), with no additional settings necessary. The physical location of the HPWC's and the 100A circuits to them wouldn't even change. The only thing that would need to change is the communication bus, master/slave settings, the feeder cable to the subpanel, and the feeder breaker, as well as any main panel upgrades to handle this (which of course would be the most expensive part). This makes management of this a lot closer to the actual cost of delivery of the electrical equipment for whatever level of charging someone has.
My "future-proofing" hypothetical house has 4 long-range Teslas that ALL drive 250 miles before coming home AT THE SAME TIME, park, charge up, and then ALL 4 need to leave again AT THE SAME TIME on another 250 mile journey within 4 hours. That might sound crazy to some, and there are "almost no places like that", except for just about every town between Stockton and Ceres including Manteca, Modesto, Tracy, etc., when the Model 3 comes out, and this could become a not unheard of occurrence (people who buy affordable homes who work where the work is around here -- so a LOT of people, that take 580 -- typically not the target market for Tesla, but who knows, some outliars will happen, and they will need more charging than most current Tesla owners would ever imagine needing, just for daily commute needs).
However, the person asking a question made me realize that a household with 150A available for charging would be in a quandry: do they put only 100A on a bus sharing that 100A, or do they set up a few that add up to less than or equal to 150A? Such as wire both for 100A, but set the first one to 64A and the second one to 56A, not bus'd. It would be nice to be able to tell the master "maximum draw from all units is 140A, all on 100A circuit breakers" or some such thing, but no luck here.
