I got this advise on another forum.
I'm sure it's legit but I don't know how to interpret this and communicate what I want/need with Tesla next week. Any thoughts on this? Thanks
As a certified Tesla installer who has designed numerous Powerwall systems I would suggest that you request your installer use a Gateway 2. This Gateway has a 12 slot internal panelboard option that can hold 3 full size 2 pole breakers or 6 Eaton Quad breakers. It can be configured to be either a unbacked up heavy load panel or an essential load panel.
The gateway 2 is a new device in the US for tesla. The "gateway" is the "computer brain / device" that does all the power load switching. It determines which direction your power is flowing (solar to home, solar to grid, solar to powerwalls, powerall to home etc). Its simply a newer version of that device, with some additional capabilities than the one most of us have.
In effect, that recommendation is just to ask for the newest computer, as it were. Tesla would likely be using it in your install anyway since you dont have it scheduled as of yet, but it wouldnt hurt to ask.
On your "how easy is it to add powerwalls later" comment, you could request that tesla wire it for adding a powerwall later, but in general I think you would pay for the price of the powerwall plus at least 1k ish of labor. It could be significantly more as well.'
If, for example you get 1 powerwall, you absolutely can not backup your whole home. As was stated earlier, its not you "deciding not to use an item during a power outage" its you, "being completely unable to turn something on whether you want to or not" during a power outage because it simply isnt wired that way. 1 powerwall can only provide up to a 30amp circuit, so they WILL rewire and move any backed up circuits to a new panel, and leave anything that isnt backed up in your old one.
This means in general, you might have the circuits for your fridge, and regular wall outlets backed up, but not much else. That may be fine with you, but if you then later (next year lets say) decide you want to add a second powerwall, and backup more circuits, or "I was told 2 powerwalls would let me backup my whole house, so lets just buy that second one in a year or two", it would basically moving the other circuits.
Translation, the second powerwall in that instance would cost likely the price of ordering just one now, including the labor, or the price of the powerwall and another 3k in labor.
The cheapest its ever going to get to get additional powerrwalls is right now, bundled with the first one.
Now, if you ordered two, and then had whole home backup already, but asked them to wire it in case you wanted a third one,... that third one would not likely cause any rewiring so it would likely be price of powerwall + 1k of labor or so to install... because it wouldnt require any circuit moving, etc.
The TL ; DR version of "how easy is it to install powerwalls later" is .... " it depends on what you start with, and how your original install is wired, but it will never be as cheap as it is to do it on the first install. It just depends whether its "moderately" more, or "the same price as installing 1 powerwall new", depending on how many powerwalls you start with and the complexity of your install."
