Newbie question: Unlocking all doors from FOB?
Discussion in 'Model S: User Interface' started by Az_Rael, Jan 16, 2017.
  1. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Background: I have the lock set to only unlock the driver door for security reasons since 90% of the time I am driving by myself. I have walk away lock turned off, and auto-present on.
    On the few occasions where my husband is riding with me, I have a hard time getting all the doors to unlock with the FOB and I am trying to figure out a consistent way to get it to work. I double-click once and my door unlocks, which is the behavior I expect. If I double click again, sometimes it unlocks the rest of the doors, sometimes it doesn't. Sometimes I have to get in and toggle the center console/park button to get the passenger door unlocked.
    Anyone have any tricks? Is there a triple click or something simple I am missing to command all the doors open with the fob?
  2. f-stop
    f-stop Active Member
    Vancouver BC, Canada
    I have my car set the same way, to only normally unlock just the driver door.
    using your fob, the first double click should open only the driver door. If you double click again just after that, it should unlock all the doors. by your description you're doing it correctly, so maybe there's a problem with your fob or car? have you tried your spare fob, does it behave the same way?
  3. Az_Rael
    Palmdale, CA
    I havent tried the other fob to see if it work better - that is a good suggestion.
  4. Maximapolak
    Maximapolak Member
    North NJ / SouthCentral PA
    It has to be done within a couple of seconds of the first unlock. That may be why it doesn't work sometimes.
