Hey Guys:
I just bought a 2013 P85 and all was well until I started getting some warning messages. First came the TPMS warning saying that it couldn’t read from all of the sensors. Then I started having issues with the Bluetooth not connecting. After looking it up, I did a deep reset of the center touchscreen. After thirty seconds of having my foot on the brake and holding in the two scroll wheels the center touchscreen went black. From what I could gather, it should have shown the Tesla logo and came back. Well, it’s been about 2 days and.....no.
I started to think that the 12 volt battery was low and not able to turn on the screen. I found the Fuse that the touchscreen used and tested voltage. Weirdly enough there was no voltage on the fuse (car off or on). I tested the fuse for the drivers side seat electric motor and it also showed no voltage. Even though I could move the seat. I then took off the nosecone and tested voltage there. I saw 13.47 volts. So that has me puzzled. Yes, its a Tesla and a little different than an ICE car, but 12 volt is 12 volt. I would assume that I would see voltage on the fuses.
After doing this, I did see some posts on the forums about pulling fuse 51 for a few minutes. I pulled it out and inspected the fuse. The fuse itself was fine. After waiting a few minutes, I reseated the fuse. I then pressed on the brake pedal and it said that it was starting up the systems. Still no center screen. After doing this, now I don’t have turn signals. I know the front headlights don’t show when I put the turn signals on and the screen behind the steering wheel doesn’t show that the turn signals are on either.
As of now, I am at a loss. One possible reason that this could be happening is the eMMC issue that is floating around. It could also be that the fuse 51, while intact, may actually be bad. The car drives, can charge and pretty much do everything just not show the center screen. It might just be better to schedule an appointment with the service center, but wanted to see if there was anything else I can try before I do.
