From the evidence presented in this thread, it doesn't look to me like software has a lot to do with this increase in recently-manufactured P90DL power levels. This appears to be solidly battery-related.
It appears to me that the batteries installed recently have a newer chemistry that reduces internal resistance overall, and reduces it even more in comparison to the older chemistry when the cells are warm.
Thus, at a 1500A load, the newer chemistry is maintaining voltage considerably higher, which equates to more power.
For the older chemistry, 455 kW of power with 1500A current is a battery terminal voltage of 303V, or about a 97V drop from the open-circuit terminal voltage of 400V.
For 510 kW (the max reported by someone in this thread) with 1500A current is a battery terminal voltage of 340V, only a 60V drop from the open-circuit voltage of 400V. That represents a HUGE 38% reduction in battery internal resistance. That may be more than just cell chemistry, that may also be beefier interconnects between cells.
We need CAN logging on a recently-manufactured P90DL to get the battery terminal voltage data to confirm, but I'll bet these voltages are exactly what you're going to see.
Another plus if this is the case is that battery internal heating is reduced. With the older chemistry, 97V * 1500A = 145 kW of power that is dissipated as heat inside the battery during a full acceleration. 60V * 1500A = only 90 kW of heat, a 55 kW reduction.
