Highly confusing what you are writing there. Comparing battery output to theoretical motor output, adding some weight and coming up with a number at the end. 670hp at the battery would be 600hp at the motor shaft, at best. So there are still , at least, 90 more hp the P100D could have, before its motors would limit the power drawn form the battery. And since we know that the battery still draws 10% more power and the P90D didn't have 200hp, the added output power should be more than 20hp. Because how show should that work? Maybe losses are perceptually a bit higher, but not that much. If you put in 10% more power you get roughly 10% more power at the other end.
