R.S
It doesn't matter whether I use shaft hp or battery horsepower since it is the ratio of powers that affects the elapsed times. I used the ratio of 670 / 690 to get the effect on elapsed time assuming the same weight. Then I used the ratio of the weights of the cars to get the effect of the heavier p100d.
You used the ratio 670/690, but why? 690 is a number that has nothing to do with either the P90D, or the P100D, if you look at battery power levels, nor at shaft power levels. You could have also used 1947/1946 since those are the birth years of both US presidential candidates. You can't just compare battery power and theoretically maximum shaft power and assume you got to a valid conclusion. That this additional power is also just available for a certain rev range, neither at the very low, nor the very high, makes your calculation even more wrong.
