Anyone know where the can bus connector on a July / 2016 model s is? I've got the hockey stick trim on the passenger side pulled back, but I can't see the connector. I've used a flashlight and can see to the other side but no connector.
Exploring the Model S CAN BusAnyone know where the can bus connector on a July / 2016 model s is? I've got the hockey stick trim on the passenger side pulled back, but I can't see the connector. I've used a flashlight and can see to the other side but no connector.
Thanks. I checked that thread and any others I could find. My car has the console, so access to the connector should be behind the hockey stick shaped trim panel on the passenger side. I can't see it, so I just wondered if anyone else has been able to locate it.
Sorry. I realized I hadn't read the rest of your comment. I think the split all depends on what's happening.
When the car is cruising steady state on the freeway with range mode on, a feature called torque sleep activates under just the right conditions and puts the rear motor to sleep essentially leaving the car a front wheel drive car. The smaller motor is more efficient at highway speeds than the larger rear motor.
Under maximum acceleration, the torque is going to be split to increase maximum traction, i.e. as much torque in each motor that is possible before traction on either axle is broken.....at least up to about 45 MPH. Up to 45 MPH, the car is traction limited, not power limited. After 45 MPH, it's hard to say what it does at that point. I would imagine the acceleration for some period of time would be more biased towards the back. But if you're accelerating out of a corner, then it's going put as much power into the front as possible without compromising traction or stability. Unless someone can log the inverter power for each inverter I don't think anyone can say.
Any of you CANBUS loggers out there know if one of the busses breaks down power from front to rear? I vaguely remember someone posting a graph showing as such.
I guess it's time to get off my but and put my cable together for TM-Spy.
The CAN bus connectors are behind the cubby (center dash). Older are white while newer are blueish colored.
View attachment 187691 View attachment 187692
TM-spy can bus analyzer:
July 2016 P90DL in ludicrous, max battery ready at 112 degrees, 94% soc.
Max power at 1615.4 amps, 310.2 volts, 501.1kw, 672 hp
The newer batteries must be running higher than 1500 amps and are probably around 1600 amps given the KWs seen.
I think you're on the right track but I'll bet it's closer to 1600 amps
Obviously, everyone is at TMC + Gigafactory event as no one is commenting...
We've been waiting for so long for this number!!!
1600A at the battery!!!!!!!!!!...with significant less voltage sag.
When I pull 1500A, the voltage of my P85DL drops to 294V.
So this is not 'only' new chemistry and reduced voltage sag, they are allowing an extra 100A to go through that programmable fuse!! :-D
That's 441KW which is a bit lower than a P85DL at 90% with max battery ready (305 volts).
P100D:
1600 x 100 / 90 = 1777, so maybe they'll push it to 1800.
Looks like the higher capacity batteries more or less maintain the same voltage but at higher current,maybe a little more.
Lets call it 315 volts at 1800 amps, so 567 Kw or 760 hp. Hmm, that's pretty close to the combined hp of the two motors, before conversion losses. Do they quote power at the output shaft?
The thing is, that power and capacity stand in no correlation, when it comes to batteries. Tesla could come up with a 150kWh pack that can only supply 300kW, or with a 95kWh pack, that has 1MW. Both unlikely, but possible. To just assume, that a 100kWh pack has 11.11% more power, is as valid as assuming that it has 11.11% less power.
Has tesla ever reconfigured the pack for the Model S? I remember in the past that the smaller packs had blanks in place to drop the capacity to whatever they were selling.
If they don't reconfigure the pack then logically they would have to change the battery chemistry.
