Peteski
I actually asked them if the specifications changed, since aligning in standard with ne specifications would effectively be the same as aligning in low, and they indicated that they have not. I also had them check my treadwear (I use standard except for automatic lowering above 65mph, which isn't much of my driving), and it was pretty uniform all the way around. I'd be happy to drive in always low if my tire wear would be even there.
Have you actually seen the alignment specifications? I have them here in front of me. The acceptable rear camber range is anything from -0.5 to -2.5 degrees! This applies to all Model X air suspension 2016-18 according to the document. So your information seems correct in that the specification hasn't changed, but the allowable camber range is a joke and goes a long way in explaining why some people have horrendous tyre wear and others perfectly even. For those who are not technically minded a range of 2 degrees in static camber is very wide and would make a huge difference to your tyre wear profiles. Probably way more change than you would see when going from standard to low ride height, which is probably less than 1 degree camber change (although I don't have data for camber change vs ride height for this vehicle).
