Next Gen seats LATCH System
Discussion in 'Model S: Interior & Exterior' started by sundoc, Nov 15, 2014.
  1. sundoc
    sundoc Member
    Ontario, Canada
    For all the lucky ones who've seen/sat in the next gen seats, has anyone seen how many LATCH points there are (child seat anchor points in the back seat)?
    Thanks in advance!
  2. andrewket
    andrewket Well-Known Member
    Sorry, I didn't think to look as my kids are past that stage. I believe LATCH is required by USDOT, though. And the latch points are part of the frame, which is likely the same frame used with the current seats. You could always call or email Tesla and ask?
    I think the more likely problem you're going to encounter is the car seats are not going to fit properly between the bolsters. I have one kid left using a booster seat, and my guess is I will have to buy a seat with a very narrow base.
  3. bollar
    bollar Disgruntled Member
    Southlake, TX
    It's almost certainly two Latch points.
  4. sundoc
    sundoc Member
    Ontario, Canada
    Yeah I'm guessing there will be at least 2 configs for the LATCH, as opposed to the 3 possible configs on the current cars (current as of the summer at least).
    We've got the Radian RXTs... Super slim seats, I've got 3 across in my current Subara STi, so hopefully it'll work even with the bolsters.
    I called the TESLA mothership but they weren't able to give me an answer.
    I guess I'll have my answers in a month or so anyway :)
    Thanks again folks!
  5. bsd
    bsd Member
    Guelph, Canada
    Note that although the MS supports 3 configurations, only 2 can be used simultaneously:
  6. sundoc
    sundoc Member
    Ontario, Canada
    Yeah I'm hoping to be able to use config 2 from above and then use the belt for the third seat, which will shortly be converted to a booster set up :)
    @ bsd
    Thanks for posting the image!
  7. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    That's not entirely true. That's an old diagram that specifically refers to LATCH seat placement. When cars used to have a center LATCH (they don't anymore), one of the two rails was shared with the outboard seat. So there were 5 LATCH anchors, making it impossible to fit 3 LATCH seats. The manual states in this case, the two outboard seats must use LATCH, and the center seat must mount with a seatbelt.
    On cars built after about December 2013 the topic is moot, as they have only 4 LATCH anchors, with none in the center position.
    So in either case, if you need three seats across, two will be LATCH and the third seat must use a seatbelt.
  8. Kalud
    Kalud Active Member
    Montreal, QC
    For your info, the Radiant works great too in the Model S.
    I had 3 across but the older one is now on a booster (green, seen behind passenger seat).
  9. commasign
    commasign Tesla Superfan
    Davis, CA
    bump. Can anyone with NextGen rear seats confirm that there are only 2 outboard LATCH positions?
  10. Puff
    Puff Member
    San Diego, CA
    Confirmed. Don't have pictures but this should do. Didn't want to mess with the seatbelt only setup for the middle seat so I strapped the baby to the latch on the outboard for simplicity.
