What was the deal with rotating the car upside down on that rig? Was that just for visual inspection after the crash test?
I believe that is to emulate a rollover following a crash.
What was up with the rear bench going to pieces like that?
My understanding is that it's generally done to check for fuel or other dangerous fluids that might leak out after a crash. IRRC the Volt test had a coolant leak that could cause a short in the battery pack.That would be really lame. No forces are applied to the car in that roll except for gravity. In reality, the car would be pounded by the road surface on every side for every roll.I believe that is to emulate a rollover following a crash.What was the deal with rotating the car upside down on that rig? Was that just for visual inspection after the crash test?
I'm all for testing EVs with a full battery. It might help further distinguish Tesla's safety advantages vs other EVs and raises the safety bar for future generations of EVs.
I agree. I don't think the mirror should break loose like that.
Back in the 70's my older brother was in a diagonal crash and his girlfriend broke her nose on the mirror. Having them pop off is probably a good idea. Having them leashed is even better.
Does anyone know when the IIHS will test the Model S? I think it will be interesting to see how it behaves in a moderate overlap frontal test and the small overlap frontal test. From what I could see of the collision between a Model S and a Honda, I have pretty high hopes that Tesla can get good grades in these tests.
What I'm most curious about is the roof crush test. The Tesla has a high curb weight, so it will have to withstand a lot of crush force in order to get IIHS' top rating (I think a rating of "Good" requires something like 4x or more the weight of the car).
My only concern (and it's a small one) is how consistently the rear view mirror turns into a projectile. This should be an easy fix (maybe even add electrical tape or wire tie to the connector so it doesn't snap off)
There was a talk with Martin Eberhard on stage where he was showing images from the Roadster crash testing. He explained the inverted fluid leak test. It passed. Maybe TEG can find it.
