File a Vehicle Safety Complaint | Safercar.gov | NHTSA).Anyone have a link to the NHTSA complaint site?
Climate control is still on.
When my MCU died, my AC also stayed on. For me taking out the MCU fuse for 30 seconds turned off the AC.
Thanks for the suggestion. Unfortunately I can’t find the MCU fuse. Here’s my fuse box layout Tesla Model S (2015)- fuse box diagram - Auto Genius
No this is not the replacement of the MCU. This the actual board failing in de MCU. This kind of repair is what tesla should have started out from to begin with. The rest of the unit is fine this board is the weak link. Good that they are addressing the faulty part. If you got your MCU replaced then your whole assembly was replaced so therefore the cost is higher.NHTSA probably already made a difference! EMMC replacement can be done for around $400 now. I payed almost $2400 ten months ago. It is 85% price reduction. I wouldn’t mind to get a refund.
They are replacing the daughterboard, on which the eMMC is installed.Is Tesla replacing the EMMC card or daughterboard for under $500 now to fix the issue as opposed to replacing the entire MCU ?
I don't know the answer to this question, and I'm guessing we won't know until someone takes it apart and checks for us. But my understanding is that it should last significantly longer since Tesla has updated firmware to reduce writes. They seemed to be writing indiscriminately to it in the past.I wonder what sort of chip is on the daughter board? If it is the same type and size that's not much of an improvement.
This post does not sound to positive.I don't know the answer to this question, and I'm guessing we won't know until someone takes it apart and checks for us. But my understanding is that it should last significantly longer since Tesla has updated firmware to reduce writes. They seemed to be writing indiscriminately to it in the past.
It's the Tegra daughterboard, and the total cost is $490 part+labor. Tesla Service confirmed they'll do that if only my daughterboard is bad on my MCU when I bring it in next week. Otherwise they'll replace with a reman MCU for $950+labor.
My estimate is from San Rafael, FYI. And good luck with the warranty claim; mine died 3 months after it's 4th birthday..I also just got a quote for replacing the daughterboard. Same part number but asking $696.30. This is in the SF Bay Area.
I am asking if it is possible to do under warranty since it died the month after its 4th birthday
I don't trust that the logging changes are enough. My current MCU is two and a half years old. I've stopped streaming. I've stopped traffic. I keep the map zoomed way out so it doesn't have to paint very much and only use nav on road trips. Hoping to keep mine alive until I can make a trip to Orange County to EVfixme for a proper repair. (Hard to make that trip safely in the era of coronavirus.)I don't know the answer to this question, and I'm guessing we won't know until someone takes it apart and checks for us. But my understanding is that it should last significantly longer since Tesla has updated firmware to reduce writes. They seemed to be writing indiscriminately to it in the past.
