Nissan manufactured CHAdeMO 25kW limitation
Discussion in 'Model S: Battery & Charging' started by nlc, Apr 22, 2015.
  1. nlc
    nlc Member
    Nantes, France
    #1 nlc, Apr 22, 2015
    Hello all,
    Here in France we have a CHAdeMO station manufacturer called DBT, which have a very bad reputation concerning the reliability of the station.
    Now we have the CHAdeMO adapter available, we found that the charging power on this station is limited to 25kW. In fact they use Nissan charger inside, thus it's a world problem on all station with Nissan hardware inside.
    On another topic, hiroshiy tolds Japan Nissan's station are limited by Model S's firmware to 25kW.
    I just found this information, and is also true for all Nissan's station in the world !!
    I confirmed this information myself by sniffing the CAN bus between the CHAdeMO adapter and a DBT charging station with Nissan hardware inside.
    In the session I done, I seen that the station indicates 107A is available, but the car only request 68A of current consign !! Which is 25kW because I was at 370V.
    I some guy are interested I can post a copy of the CAN bus data I recorded, but I will not explain the CHAdeMo protocol in detail (I bought the official CHAdeMO specification for my personal interest).
    Regards,
    Cyril
    - - - Updated - - -
    Here is how I connected to the CHAdeMO signals, GND , +12V, CAN_H, CAN_L
  2. J-Philipp
    J-Philipp Member
    Senlis (France)
    #2 J-Philipp, Apr 22, 2015
    Ithink you're referring to this post from Hiroshiy.
    http://www.teslamotorsclub.com/showthread.php/42176-CHAdeMO-Make-Model-Review-%C2%97-Using-with-a-Tesla/page7?p=928377&viewfull=1#post928377
    I guess that Tesla accepted to limit the intensity at 67 A to protect all these Nissan/DBT slim chargers from smoking when the CHAdeMO adapter was finally released to Model S owners.
    Sadly this type of charger is very common in France, and I would never have bought this CHAdeMO adapter had I known it would give only 25 kW. This same type of charger is a equipped with one type 2 plug that can deliver 22 kW with my double chargers.
    So, what's next ? Will this limitation eventually be lifted ?
  3. RiverBrick
    RiverBrick Active Member
    Mount Washington Valley
    I also have the 25 kW limit, based on visits to six different Nissan stations in the USA. However, in North America, some Tesla owners do not have power capped at these same stations. I has the .179 build of version 6.1 during these six sessions.
  4. nlc
    nlc Member
    Nantes, France
  5. kseitzberg
    kseitzberg Member
    Denmark
    I have tried 3 different CHAdeMO stations in Denmark. All of them Siemens and charged at up to 48 kW at these stations with a low SOC. As when supercharging power drops when almost full.
    P85D With firmware 6.2
  6. nlc
    nlc Member
    Nantes, France
    Maybe these stations use an older firmware ?
    Because I ask myself how the car can know it is connected on station with Nissan hardware.
    On my CAN data messages recorded, the very first CAN message is an ID which does not exist in the CHAdeMO specification. It's the ID 0x62F, with 8 data byte : 00 44 03 01 00 01 00 01
    The message just appear one time, but I don't know if it comes from the car or from the station. If it comes from the station, it can be a specific message to tell the Tesla to lower it's max current request ?
  7. J-Philipp
    J-Philipp Member
    Senlis (France)
    All CHAdeMo stations tested did not show this limitation. It is only related to NISSAN Quick Charger hardware. There must be an agreement between Tesla and Nissan to protect them. Why would the station tell that the maximum is 107A and the car draw only 68 ?
  8. nlc
    nlc Member
    Nantes, France
    Yes, that's the normal behavior, on all other station which does not embed Nissan hardware :D
    Here in France the CHAdeMO adapter also work at full power on other station manufacturer, Saintronic, SGTE-Power, EV-Tronic, etc...
    But the problem is that a very high number of station are DBT station, with Nissan hardware, and we bought the CHAdeMO adapter to charge at 25kW rate :(
  9. bluetinc
    bluetinc Member
    MD
    Great information here!
    A note about Tesla's CHAdeMO adapter, they run software/firmware inside which Service Centers can update. I recently had an issue where I could not charge on a specific type of charger, and Tesla updated the software/firmware in the adapter to correct the issue. Unfortunately I don't know of any way to check the version number of the adapter software/firmware.
    Peter
  10. nlc
    nlc Member
    Nantes, France
    Interesting information, they probably have a tool to reflash the adapter trough the CAN bus interface :)
    - - - Updated - - -
    A friend who had the adapter in beta testing has successfully charged on Nissan station at full power, but now it is limited too. And his adapter have not received a firmware update. Thus it's probably the car firmware which manage this limitation. Now I want to understand how the car can detect the Nissan hardware and apply the limitation
  11. RiverBrick
    The discrepancy of some getting 40 kW while others are capped at 25 kW is happening not only on the same model of Nissan hardware, but also on the same units at the same locations. Therefore, I don't think it is caused by station firmware.
    An example is the CHAdeMO at ATC Drivetrain North in Oklahoma City:
    http://api.plugshare.com/view/location/14299
    TrueEV (a TMC Member) and Jay both got over 100A with the adapter at this location, but I had the dreaded 60-70A cap.
    The positive is that none of the Nissan CHAdeMO stations overheated or otherwise stopped working while I used them.
  12. Matias
    Matias Active Member
    Finland
    Location?
    Is there some easy way to disable GPS?
  13. nlc
    nlc Member
    Nantes, France
    Same car firmware ?
    - - - Updated - - -
    It can be GPS, but from RiverBrick answer, I think not, except if a list of location must be updated in the car
  14. RiverBrick
    In California, there are many evGO network locations with Nissan CHAdeMO and ABB dual-standard stations side-by-side. So, someone there could test this.
    - - - Updated - - -
    I can only say I had the .179 build of 6.1. I will try to find out the others.
  15. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    Hi, this is done based on the agreement between Tesla and Nissan, by car firmware detecting Nissan slim chargers. Right now many Japanese owners complained and Tesla is seeking some remedies. Nissan also seems to be improving the hardware but by Japanese communication standards they won't make it better soon, especially already installed units. I'm a bit frustrated why Tesla takes weak approach to Nissan's own problems, or result of design flaw.
    Tesla announced on their Japanese blog that they will try 44kW for 30 min then 25kW afterwards, instead of current 25kW flat. I also proposed to evaluate 44kW flat for 60 (or shorter) min and nothing after that too.
    Due to this limit, we can't travel to north or northwest of Tokyo, without waiting for a long time at 20kW or 25kW CHAdeMOs. The bigger issue is that there are CHAdeMOs on highway service plazas, the ones on northwest route are all Nissans... And since they are very busy, if someone comes up while I'm charging, I have to give up charging in only 30 minutes, resulting in 60km worth of charge.
    It's between two choices for us Tesla owners and Tesla itself.
    (1) Give up being good EV citizen and lift the power limit, resulting in frequent overheating and breakdowns of Nissan chargers. If maintained correctly, it works at least 90 minutes continuous.
    (2) Tesla try to pressure Nissan to cooperate, and jointly try to find the absolute highest sustainable power limit, that may break some of the non-maintenanced units. Nissan try to ask owners to properly maintain the units (1000s), and potentially recall.
    If Tesla keeps 25kW here they'll lose Japanese market.
    So if you are bothered by this limit please convey your opinion to Tesla. They need to come up with something that work both for us and them, possibly Nissan.
  16. hiroshiy
    Tokyo, Japan
    FYI in addition to 25kW problem, some CHAdeMO chargers are not compatible with Tesla, including Nissan slim chargers. With incompatible Nissan, in many cases you keep retrying to charge bit by bit, if it's emergency.
    Here's my and my colleague's "didn't work" list. If you are betting on one, just think about non-Nissan units as a backup!
    CHAdeMO
  17. nlc
    nlc Member
    Nantes, France
    You are right, that's Nissan own problem, I don't understand why Tesla accepted an agreement with them. That's a design flaw on their hardware, they are lying when selling these station for 44kW power !
    There are 2 design flaw :
    - The station doesn't accept 44kW for a long time
    - They have no temperature sensing to lower current by itself in case of overheating !?
    For now, Tesla only is impacted, but in the future, the Leaf will come with a stronger battery pack > 40kWh, they will have the same issue on their own car !!!
    Here in France, we have not a lot of SuC, and a big part of them only have 2 stalls. Thus we all ordered the CHAdeMO adapter to be able to charge elsewhere, and we are all very frustrated to be limited to 25kW, because a big part of the station are DBT with Nissan hardware inside :/
    You are right, we should all complain to Tesla, to find a solution as soon as possible
    - - - Updated - - -
    Is an administrator can change the title of this thread to : "CHAdeMO 25kW limitation on Nissan station" ?
  18. hiroshiy
    Tokyo, Japan
    In just two years, Model 3 comes out with 50-60kWh battery, Bolt with 50kWh, Leaf with 40-50? battery, effectively requiring more than 30 minutes of continuous 44kW charging.
    At that time Nissan chargers will start overheating a lot and they may realize the real issue of their plan. In addition, more than 70% of CHAdeMO chargers here in Japan are less than 30kW and they'll be useless in two years.
  19. nlc
    nlc Member
    Nantes, France
    Here is a complete log of a short charging session this afternoon.
    #xxxx is the CAN identifier
    The 0 is the remote request bit, alway zero
    The 8 is the number of byte in the frame, alway 8
    And after there are the 8 byte of data of the frame.
    Identifiers #0100, #0101, #0102 are coming from the car, and identifiers #0108 and #0109 are coming from the station
    The identifier #062F is unknow, maybe a frame sent by the station to tell the car it's a Nissan station !?
    Code:
    #062f 0 8 0044030100010001
    #0100 0 8 00000000a901ff00
    #0101 0 8 00fffe0000000000
    #0102 0 8 0198010000009100
    #0108 0 8 01f4016ba9010000
    #0109 0 8 010000000020fffe
    #0102 0 8 0198010000019100
    #0109 0 8 010300000020fffe
    #0109 0 8 010400000024fffe
    #0109 0 8 015500020024fffe
    #0109 0 8 01b500010024fffe
    #0109 0 8 01f500010024fffe
    #0109 0 8 013501020024fffe
    #0109 0 8 016c01020024fffe
    #0109 0 8 01a101020024fffe
    #0109 0 8 01d201020024fffe
    #0109 0 8 01f801010024fffe
    #0109 0 8 01f901000024fffe
    #0109 0 8 01e101000024fffe
    #0109 0 8 01ca01000024fffe
    #0109 0 8 01b501000024fffe
    #0109 0 8 01a101000024fffe
    #0109 0 8 018d01000024fffe
    #0109 0 8 013801000024fffe
    #0109 0 8 01dd00000024fffe
    #0109 0 8 019d00000024fffe
    #0109 0 8 017000000024fffe
    #0109 0 8 015000000024fffe
    #0109 0 8 013a00000024fffe
    #0109 0 8 012a00000024fffe
    #0109 0 8 011e00000024fffe
    #0109 0 8 011600000024fffe
    #0109 0 8 011000000024fffe
    #0109 0 8 010c00000024fffe
    #0109 0 8 010900000024fffe
    #0109 0 8 010700000024fffe
    #0109 0 8 010500000024fffe
    #0109 0 8 014301000024fffe
    #0109 0 8 015701000024fffe
    #0109 0 8 016101000024fffe
    #0109 0 8 016601000024fffe
    #0109 0 8 016b01000024fffe
    #0102 0 8 0198010100019100
    #0102 0 8 0198010200019100
    #0109 0 8 016b01000005fffe
    #0102 0 8 0198010400019100
    #0102 0 8 0198010600019100
    #0102 0 8 0198010800019100
    #0109 0 8 016b01020005fffe
    #0102 0 8 0198010a00019100
    #0109 0 8 016b01010005fffe
    #0102 0 8 0198010c00019100
    #0102 0 8 0198010e00019100
    #0102 0 8 0198011000019100
    #0102 0 8 0198011200019100
    #0102 0 8 0198011400019100
    #0109 0 8 016c01030005fffe
    #0102 0 8 0198011600019100
    #0109 0 8 016c01090005fffe
    #0102 0 8 0198011800019100
    #0109 0 8 016d010f0005fffe
    #0102 0 8 0198011a00019100
    #0109 0 8 016d01120005fffe
    #0102 0 8 0198011c00019100
    #0109 0 8 016d01150005fffe
    #0109 0 8 016d01170005fffe
    #0102 0 8 0198011e00019100
    #0109 0 8 016d01190005fffe
    #0102 0 8 0198011f00019100
    #0109 0 8 016e011c0005fffe
    #0102 0 8 0198012000019100
    #0109 0 8 016e011e0005fffe
    #0102 0 8 0198012100019100
    #0109 0 8 016e01200005fffe
    #0102 0 8 0198012200019100
    #0109 0 8 016e01220005fffe
    #0102 0 8 0198012500019100
    #0109 0 8 016e01230005fffe
    #0102 0 8 0198012600019100
    #0109 0 8 016f01250005fffe
    #0109 0 8 016f01260005fffe
    #0102 0 8 0198012900019100
    #0109 0 8 016f01270005fffe
    #0102 0 8 0198012b00019100
    #0109 0 8 016f01290005fffe
    #0102 0 8 0198012d00019100
    #0109 0 8 016f012b0005fffe
    #0102 0 8 0198012e00019100
    #0109 0 8 016f012d0005fffe
    #0102 0 8 0198013000019100
    #0109 0 8 016f012f0005fffe
    #0102 0 8 0198013200019100
    #0109 0 8 016f01310005fffe
    #0109 0 8 016f01320005fffe
    #0109 0 8 017001320005fffe
    #0102 0 8 0198013800019100
    #0109 0 8 017001330005fffe
    #0102 0 8 0198013a00019100
    #0109 0 8 017001350005fffe
    #0102 0 8 0198013c00019100
    #0109 0 8 017001370005fffe
    #0102 0 8 0198013d00019100
    #0109 0 8 017001390005fffe
    #0102 0 8 0198013e00019100
    #0109 0 8 0170013b0005fffe
    #0102 0 8 0198013f00019100
    #0109 0 8 0171013d0005fffe
    #0102 0 8 0198014000019100
    #0109 0 8 0171013f0005fffe
    #0109 0 8 017101400005fffe
    #0102 0 8 0198014100019100
    #0109 0 8 017101410005fffe
    #0102 0 8 0198014200019100
    #0109 0 8 017101420005fffe
    #0102 0 8 0198014300019100
    #0109 0 8 017101430005fffe
    #0102 0 8 0198014400019100
    #0109 0 8 017101440005fffe
    #0109 0 8 017201440005fffe
    #0109 0 8 017301440005fffe
    #0109 0 8 016d010000240000
    #0109 0 8 01b6000000240000
    #0109 0 8 0158000000240000
    #0109 0 8 012a000000240000
    #0109 0 8 0115000000240000
    #0109 0 8 0110000000240000
    #0109 0 8 010c000000240000
    #0109 0 8 0109000000240000
    #0109 0 8 0106000000240000
    #0109 0 8 0105000000240000
    #0109 0 8 0104000000240000
    #0109 0 8 0103000000240000
    #0109 0 8 0102000000240000
    #0109 0 8 0101000000240000
    #0109 0 8 0100000000240000
  20. dlt
    dlt Member
    Finland
    Thanks, nlc! This is really useful information. Here in Finland about 95% of fast charging stations are unfortunately these nissan/dbt units, and we have received first chademo adapters.
    There have been a lot of discussion going on here about 25 kW limit and who has to fix it.
    Your findings confirm our guesses. We have seen full power (not 25kW limited) charging on old Tesla car firmware here too, with same adapter + dbt combination giving only 25kW to a car with up-to-date firmware a couple of days later.
