let me correct you, in reality under normal driving you can expect a little more than 72 miles of range from the car, 107 if you never exceed 35mph is possible, factor in cold, wind or range and ranges take a big hit. After using your 70+ miles of range without chademo charging, using L2 charging
you're down for 6+ hours to recharge.
this might work well for people who have well defined travel patterns, commuting for example. I am not ragging on the LEAF, I owned one, but for many people 70+ miles or range
just doesn't cut it.
I think you need to add kWh into that post. What you say is right about the 24 kWh pack but not the 30 kWh pack and I think you are confusing the two.
24 kWh pack is advertised at 84 miles range
30 kWh pack is advertised at 107 miles range
I can defiantly get 100+ miles range driving a 24 kWh pack at low speeds like you claim I need to. I can get way more on the 30 kWh pack. Lets toss some real numbers out.
24 kWh pack has about 21.4 kWh usable ignoring turtle mode and top/bottom protection
30 kWh pack has about 25.75 kWh usable given the same caveats.
Multiply that by your favorite miles per and the 30 kWh pack will do
129 miles at 5.0 m/kwh
121 miles at 4.7 m/kwh
115 miles at 4.5 m/kwh
108 miles at 4.2 m/kwh
103 miles at 4.0 m/kwh
I'm averaging 4.4 miles per kWh with my 2012 for the last year. I see well over 5 in the ideal situations (warm with no AC use) and below 4 in the winter (cold and heated seat/heated steering wheel/cabin heat use) but tend to hang out in the mid to high 4s most of the year even when using AC or heated seats/wheel.
Maybe your "normal driving" isn't so normal or you are talking about the 24 kWh pack which is
105 miles at 5.0 m/kwh
99 miles at 4.7 m/kwh
95 miles at 4.5 m/kwh
88 miles at 4.2 m/kwh
84 miles at 4.0 m/kwh
or maybe you are just afraid to drive the leaf below the low battery warning and are ignoring a huge amount of range between low battery warning, very low battery warning, and just above turtle.
Seriously there is no reason for a Florida driver to wimp out at 70 miles in a brand new leaf. Now after a year or two of degradation sure, I'll grant you the leaf range shrinks faster on a yearly basis than any other EV.
But that doesn't mean you can't get 100+ miles in real world driving. If you lose 5% a year to heat your max range drops noticeably, just don't blame that on slow vs normal driving.
