[NL] Loloo, a community driven network of charging stations
Discussion in 'Belgium and the Netherlands' started by widodh, Oct 15, 2011.
  1. widodh
    widodh Model S 85 and 100D
    Middelburg, The Netherlands
    The New Motion is a Dutch organization which informs potential EV-drivers/owners and also guides them through the whole process of buying a EV and setting everything around it up.
    Now they've come up with Loloo, a community driven charging station network. You install a charging station at your house and set it open to the public. All the kWh's other people charge at your house, you can use those again when charging abroad.
    The charging stations detects the amount of power available in your house and gives all you have got spare to the charging EV.
    You can see this as slow Level 2 charging, since it will probably be limited to 1x16A (3.6kW) for 99% of the time.
    It is completely different from the public charging stations which have 3x16A, but this is not intended to replace those, it is intended to be additional to those.
    Very nice to see that so many different projects are being initiated. Which ones will survive? Only the future can tell I guess.
  2. ebullio
    ebullio Active Member
    Rotterdam, Netherlands
    Dat Loloo zie ik het niet worden Wido
  3. m0rph
    m0rph Member
    Belgium
    Nu al terug offline gehaald? :)
  4. Daniel 74
    Daniel 74 Active Member
    The Netherlands
    Gaan wij met de kennis van nu reageren op 5 jaar oude berichten van Wido?
    Dezelfde Wido, die er destijds met zijn sterke lobby voor heeft gezorgd dat alle Tesla's na de roadster op drie fase krachtstroom kunnen laden?
    Dat is wel lef hebben... ;)
  5. ebullio
    Ik dacht, laat ik eens het oudste draadje van de Benelux bumpen :)
