No camber adjustment?
Discussion in 'Model 3' started by Cricket88, Jan 12, 2018.
Tags:
  1. Cricket88
    Cricket88 Member
    Los Angeles
    Got a chance to get under the car today and in quick glance I noticed that we have no camber adjustment provisions (that I could see without removing any parts) for either the front or the rear. Only TOE-IN and TOW-OUT.
    might be good to know in case you decide to lower your 3 (by means of aftermarket springs, or cutting coils, etc.
    . I did not see any camber adjustment points or bolts in neither the top control arms, or spindles, or lower control arms. While this can be typical to see in the rears of vehicles, I’m surprised that the fronts don’t have camber adjustments (by way of eccentric bolt, or shims). Maybe I overlooked something but perhaps others can confirm.
    But I do have Alcantara headliner
  2. stayfocus18
    stayfocus18 Member
    nyc
    thanks for the info
  3. Lasttoy
    Lasttoy Member
    St Augustine, Fl
    This strange, my back tires blew, worn on inside. Some say toed out too far. I was in SC last week. Look at printout and you camber reading.
  4. Skidmark
    Skidmark Member
    San Jose, CA
    Your camber readings aren't too bad. Toe is usually the culprit for heavier inside wear.
  5. Cricket88
    Cricket88 Member
    Los Angeles
    I’ll investigate some more later next week when I drop the 3 off at Eibach for measurements and prototyping!
  6. kbecks13
    kbecks13 Member
    SoCal
    :D:D:D
  7. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
  8. 03DSG
    03DSG Member
    Canada
    Minus 2.1 degrees negative camber on your rear drive wheels is asking for inside tire wear. No question.
  9. iwannam3
    iwannam3 Member
    Washington
    My MB C-230 Kompressor alignment required a kit installed to allow for adjustment, it is non-adjustable out of the factory.
