No electric roof?
Discussion in 'Roadster 2022' started by wenkan, Nov 10, 2019.
  1. wenkan
    wenkan Member
    Seattle
    According to the die cast model there seems no room for electric convertible mechanism in roadster 2020. The driver have to manually remove the roof and stow it in the trunk. Just like C8 base model.
    This seems a little bit below the average for a 200k supercar, but it does bring more confidence on setting a lap record on the ring.
  2. felixtb
    felixtb RsEU502,Sp+14274,XpEUSig4
    Lausanne, CH
    Koenigsegg is quite a supercar and has no electric roof...…….. and is just a tad more expensive...… just saying.
  3. AMPd
    AMPd Active Member
    Northern California
    Wouldn’t that add weight?
    I’d much prefer a manually removable glass or carbon fiber option.
  4. Pinot.Noir
    Pinot.Noir Member
    Livermore, CA
    I will likely never remove the roof, but at least I know I can.
  5. MaxPowers
    MaxPowers Member
    NW Pacific
    Why wouldn't you remove the roof? Isn't that the whole point of getting a roadster?
  6. Pinot.Noir
    Pinot.Noir Member
    Livermore, CA
    Power and performance are primary. Also, it's gorgeous. The range is a huge plus as well. The roof is minor, to me at least.
  7. wenkan
    wenkan Member
    Seattle
    Yeah if you go to the 1M and above range then this becomes pretty normal. Hypercars like 918 and LaFerrari all have manual roof.
    But at 200k I would expect the more comparable models are R8, 488/F8, Huracan or Mclaren 570s/720s. They all have electric convertible roof. If you buy a 200k car, you want to look cool.
  8. wenkan
    wenkan Member
    Seattle
    If I have the choice, I would rather use falcon wing doors on tesla’s supercar (“not a roadster”), which looks way cooler.
