No front plate?
Discussion in 'New England' started by RyanDe, Jun 20, 2018.
  1. RyanDe
    RyanDe Member
    Massachusetts
    thining about taking it off in MA, tan without it on my bonnet for 10 years no issues. Anyone take it off?
  2. tliving
    tliving Member
    New England, USA
    I went without for 4 years but now MA requires the inspectors to video and take pictures of the inspection so I couldn't find anyone to pass it now. I attached it cleanly with no drilling with 3 zip ties.
  3. RyanDe
    RyanDe Member
    Massachusetts
    I would always just tape it on during inspection and take it off when I left.
  4. tliving
    tliving Member
    New England, USA
    They're supposed to prove its not temporarily attached.
  5. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    CA says "attached". 10% of all vehicles in CA do not have front license. Maybe that's part of MA income.
  6. colinrego
    colinrego Member
    Westborough, MA
    Does anyone have recommendations for removing the front plate from a Model 3? They use a (assumed) very strong adhesive. I would like to remove the front plate/bracket, but don’t want to risk damaging anything underneath.
  7. North75
    North75 Member
    MA
    I must be crazy, because I actually think the front plate looks fine or might even help break up the big flat front a bit. I'm leaving mine on.
  8. SureValla
    SureValla Member
    Shelton, CT
    apply heat and the adhesive should gel enough to remove safety
  9. tga
    tga Supporting Member
    New Hampshire
    If attached with foam tape, you can also work dental floss in behind it. Saw back and forth to cut through the foam, them use goo-gone, WD40, or bug & tar remover to clean off any residue. That works well for removing dealership logos, badges, etc.
  10. sc123
    sc123 Member
    MA
