No longer sleeping after 2021.4.11
Has anyone had their car stop sleeping after the latest update? I left on a trip last week and left my car at home. A camera in the garage has been reporting a "sound" event nearly every 15 min for over a week. The car stays awake for approx 15min, then you hear the relay click and it sleeps for 3-5 min, then you hear it click and wake back up starting the cycle again. My Unifi network logs also confirm this behavior. Before I left it was doing this some so I tried the following with no luck. No surprise my car is now draining about 5% per day jut chilling in a 70 degree garage.
1) Hard Reboot (Dozens of times)
2) Power Off in the menu
3) No 3rd party apps and even changed my Tesla password.
4) Disconnected USB devices
5) Switched from V3 wall connector to mobile connector
6) Turned off WiFi
I've been looking and have not seen anyone else report this, but after returning and trying all the troubleshooting steps again I'm looking at which issue type to file it under in the service section of the Tesla app. I've had my Dual Motor Model 3 for 2.5 years and never experienced this.. If anyone has a suggestion on something else to try that might help it sleep, I would appreciate your experience.
Reactions: KenC
Thanks @Stevs6382 . After my service rep tried all sorts of things to fix it, I showed him your invoice and they decided to try replacing my chargeport ECU as well and that seems to have fixed it.
I can't imagine the software update broke it but maybe there is some incompatibility with the latest code/features introduced in 2021.4.11? In either case, I'm on 2021.4.12 (I waited to report the issue, hoping 2021.4.12 would fix it) and no longer have the issue.
I’m glad I could help someone short cut the diagnosis and repair process for this issue. That‘s what this forum is all about!
Reactions: PCTAZRichard
Upvote 0
RLEE
236
126
PA
I was hoping that the recent Android app update would fix this while my sc is still waiting. I set a security camera next to the charge port last night and I still have the contactors going on and off every 15 minutes. Have a good video of it now... my total range has dropped a lot this past week also, hope it's not related.
Upvote 0
I've got a 12/18 build doing this too and it got a new charge port back in December, but nothing mentioned about the charge port ECU. I kind of want to wait until the next SW revision pushes out to see if it's fixed before scheduling mobile service. Currently on 2021.4.12.
Made a service appointment in the app at the Latham service center but told them I'd do Mobile Service if possible. They have their "technical review team" looking into it. I provided them a window of time the problem was occuring so they can check the logs and see what was going on. Also mentioned charge port ECU, so we'll see if they agree.
Upvote 0
Also happening 2016 model S with CCS charging upgrade.
Glad. I found the thread, though one of my smart charging apps was causing it but changed password to disconnect all API links and it’s intermittently come back.
It does only seem to be when charge needed, thread makes me wonder if it’s related to the navigation charge point updates for showing free stalls, etc.
Upvote 0
Just got a response from the tech team. They are ordering me a charge port ECU based on my car’s logs because it is the only thing they know of that fixes this problem at the moment. The root cause has not been found. It could be software, it could be hardware, but since this ECU fixes it they’re just gonna do that and get my car sorted. Will report back whenever it comes in and they can install it via mobile service.
Upvote 0
Mobile service came out and replaced my chargeport ECU today. My car is sleeping for the first time in a month while plugged in. Took mobile service about 45 min to do and they said they would be watching the logs for few days to confirm. The chargeport ECU appears to be the fix until they can figure out a software patch, hopefully.
Reactions: Stevs6382
Upvote 0
So glad it worked for you too. I had mine replaced about a week ago and it’s been working perfectly ever since.
Reactions: TM3ATX
Upvote 0
They want me to wait a week or two for a firmware fix... anyone else get this response?
Yep, I thought I’d come back and give an update too. I dropped off my car at the Marietta, GA, service center on Saturday and got it back today. They initially said they were unable to replicate the issue, so we exchanged a few more messages where I detailed the problem case (plugged in, not charging, sentry off). I also provided the invoice from @Stevs6382 (thanks again!), and they said that helped quite a bit.
They conferred with Tesla Engineering who acknowledged the problem to be a known issue with the 2021.4 firmware and that the fix will be software and not hardware. They did not provide details as to a version number or estimated timeline for the fix rollout, but they said they would bookmark my account and let me know when they have that info. Apparently, the charge port ECU replacements were sort of a “big hammer” method initial fix since that solved the problem in the early cases. They seem to now be advising everyone else to wait on the software fix though.
Reactions: Ted H and TM3ATX
Upvote 0
RLEE
236
126
PA
Thanks for the reply and confirmation that is not just me and my sc. I hope it's going to be fixed soon via software... I've been waiting over 2 weeks now since I've scheduled with service, problem has been happening since 2021.4.11.... I really like scheduled charging for my daily drive but not if it takes in hundreds of charge/contactor cycles for no reason.
Reactions: cwhite51
Upvote 0
datoda
200
145
NH
The mobile service came and replaced my charge port ECU yesterday. Since the repair, the car has been able to fall asleep even when plugged in.
FWIW, the tech shared that changing the ECU doesn't work in all cases. I feel blessed that it's working for me (and I am keeping my fingers crossed that the problem won't return).
Upvote 0
RLEE
236
126
PA
Another update, they decided to take the car in tomorrow as planned (instead of waiting for software). They wanted to do Uber but I have a medical condition that makes ride share (especially with my commute distance) too risky. They were very accommodating and are providing me with a loaner. So far I'm very pleased with this new service center.
Upvote 0
Does anyone know where this part is located? I’d like to see what part number I have before it’s swapped out tomorrow. Thanks!
I did not go and look too close while they were working, but it appears to be in the trunk near the charge port. They just pulled back the liner to access. It was a white plastic box, maybe 4"x3" and about 1/2" thick. (don't quote me on the measurements)
Upvote 0
Cool, thanks! There’s a ton of them on eBay, that was a good place to get some photos of the unit.
Upvote 0
I received a notification that 2021.4.13 was available to install on my car. After installing it this morning, I thought I’d see if it happened to fix the problem. I currently have my car plugged in at home, not currently charging, and it has been asleep for 15 minutes so far. It usually didn’t stay asleep for any more than 1-3 minutes before. This could be the fix, but we’ll see if this keeps up.
Upvote 0
