Just to reiterate, when I last ran my survey in September, I found that fully 1/4 of all people had used either a 10-30 or 14-30 dryer plug to charge their car in the last 12 months. They may have only used it once, but they did use it.
More California centric thinking. The whole west coast, wow. Oregon and Washington too? This just proves my point. There is a lot more country than the west coast and most of it doesn't have near the EV infrastructure that you do. The rest of us need all the charging opportunities that we can get. Tesla engineers and marketing really need to get out more and stop believing their hype about supercharging being the answer to all long distance travel, at least until there are double or triple the number of supercharger locations outside of California than we have now.I wanted to load up on all these adapters when I first got the Tesla.
After 28,000 miles in the last 10 months, there is no point. I only charge at home (HPWC), Superchargers, and rarely, at destination HPWCs or J-plugs such as at hotels. That's it. I've never come close to even feeling the need for a dryer plug. Yes, I live in the SF Bay Area, but I've driven the whole West Coast. K
Of course the survey only included people on the forums, which is not the typical mainstream Tesla owner. Early adopters and EV enthusiasts would be more likely to be adventurous about charging than the typical buyer now. Even so, if the percentage dropped to 5 or 10% of all users that would still show significant need.Just to reiterate, when I last ran my survey in September, I found that fully 1/4 of all people had used either a 10-30 or 14-30 dryer plug to charge their car in the last 12 months. They may have only used it once, but they did use it.
All of this discussion makes me wonder what company will create a universal wired adapter. Separate red, black, white and green wires with protective insulated covers to insert into each of the socket holes individually.
Thanks for the reminder! I've been meaning to add a plug tester to my kit, and possibly a polarity switcher for plugs wired wrong, and an adapter with ground lug and some wire to add a missing ground.I've had this same thought, particularly when I showed up at my conservative father-in-law's place in rural Utah and was presented with a 14-30 outlet and a 6-50 outlet with no way to plug into them.
One wish I've had was wishing the UMC wasn't so sensitive to bad grounds or switch poles. We've stayed at some older motels where every plug we tried came up with a bad grounding error on the UMC and we were unable to charge at all. Its really frustrating to have all this electricity around you in your room, but the car is too finicky to drink from it...
Time to visit a nearby RV park for a quicker and more reliable charge! My early Model S road trips required RV park stops. Supercharging and destination charging fill the gap today. Encourage those motels to consider a functional EVSE for their guests or to hire an electrician for their grounding problem....One wish I've had was wishing the UMC wasn't so sensitive to bad grounds or switch poles. We've stayed at some older motels where every plug we tried came up with a bad grounding error on the UMC and we were unable to charge at all. Its really frustrating to have all this electricity around you in your room, but the car is too finicky to drink from it...
Great looking holder for your adapters. Where did you source it?
It's not so much an "extra" ground as it is just a ground. the adapters are made to add a ground to old 2-prong outlets, but there's no reason you couldn't use one with a 3 prong outlet that doesn't have a proper working ground. You can find them all over the place, but here's an example: Amazon.com: AXIS 45086 3-Prong to 2-Prong Electrical Adapter - 2 Pack: Electronics the little tab is where a ground wire attaches.I like green1's suggestion. Could there be any safety issues if running an extra ground wire to a grounded water pipe or other ground would be necessary? Insulated gloves might be smart.
After an new 8 foot ground rod has been hammered into the ground, it couldn't be removed for reuse elsewhere without great effort. If a new ground rod is necessary, IMHO, the owner of that electrical outlet needs to hire an electrician to permanently fix the grounding problem....Otherwise you'd need a ground rod which is much more of a challenge.
I actually don't have any idea, lol.
I was getting some luggage out of storage for a trip a while back, and one of the suitcases had that tucked in to one of the little carry-on bags that came with it. As soon as I saw the elastic bands I had a light-bulb moment, and went and grabbed my adapters (which I had been keeping in a small nylon velco-close bag), and they all fit in there perfectly.
It's some no-name cheapy luggage brand. I'll see if I can get a name off it and post here.
They're not usually used permanently at home, most use of these adapters has been with traveling.The disappearance of the Tesla dryer outlet adapters makes me wonder if Tesla Motors wants new dedicated Wall Connector, EVSE or NEMA 14-50 installs rather than connection to older existing circuits for permanent use at home.
They are especially handy when staying with friends and family.They're not usually used permanently at home, most use of these adapters has been with traveling.
Hence the "much more of a challenge" part, which was basically my way of saying you couldn't practically do it.After an new 8 foot ground rod has been hammered into the ground, it couldn't be removed for reuse elsewhere without great effort.
Yes, no matter what issue the vehicle detects that it refuses to charge, the correct answer is for the owner of the outlet to get an electrician to fix it. But if you aren't the owner of the outlet, you don't really have much control over that part, so the remaining question is what other options do you have to get enough electrons moved around to allow you to continue your trip. I'd definitely be willing to try a water pipe ground, a polarity switcher, or a meter box clamp if those would get me to the next charger.If a new ground rod is necessary, IMHO, the owner of that electrical outlet needs to hire an electrician to permanently fix the grounding problem..
Absolutely! Those venturing far from civilization would be wise to plan ahead and have the extra supplies handy....I'd definitely be willing to try a water pipe ground, a polarity switcher, or a meter box clamp if those would get me to the next charger.
It's already too late to get one now, at least from Tesla.Oh crap. I'd better go get one of these adapters for my Jesla while I still can. My RAV4 EV can't adjust the current - it's totally dependent on the pilot signal being correct.
