No power?
Tommie66
46
3
Nj
So I had remove the main battery due issues with one sheet
Removed the sheet and disconnected a few cells (4) in the brick that were draining it down . Charged the battery and it had over 360 volts when I just installed it!
Nothing comes up unless I jump with 12 volts in in rh wheel well?
I get Aps inhibited due to low brick voltage? I do not have the Cooling lines hooked up yet and don’t know if that would cause it?
markwj
Moderator, Asia Pacific
Apr 10, 2011
4,584
1,180
Hong Kong
I suggest that you pull the logs, to see all the individual brick voltages. Or measure directly in the ESS.
Reactions: ICON
