I have a plug kit. Good reviews but never actually used it.
https://www.amazon.co.uk/dp/B003VE0ZL6/ref=cm_sw_r_cp_apa_fab_AorCFbPDT0DZK
In light of the model 3 not having a spare wheel. What are you folks carrying in your model 3 to cover you in the event of having a puncture? In a way I'm surprised Tesla don't use run flat tyres, which came to the rescue a few times in my last car.
Ten days ago I ran over a stone or something in the road in the middle of nowhere in the Lake District. It tore a hole about 1cm across in my near side front tyre, which of course deflated instantly. No spare wheel, no repair kit (the hole was probably too big for that anyway) and no phone signal. So I took a chance and drove the 15 miles back to our hotel in Braithwaite, sometimes at 40mph. The next day I drove a couple of miles into Keswick. The deflated tyre coped remarkably well. Apart from the slightly heavy steering I wouldn’t have known I had a flat.
I have an M3P with the 235/35 Michelin Pilot Sport 4s.
That was brave! Sure the alloy isn't ruined?
Tends to be potholes that wreck them since the impact is transmitted through to the rim. If the stone hit the middle away from the rim it would be okIt was more a case of necessity! The wheel hit the stone with an almighty thump, and given the reports on this forum in the past that the 20” alloys are quite fragile I’m surprised it survived. The tyre company inspected it thoroughly though and I’ve had no problems since.
The tyres have a foam lining I believe that interferes with that stuff. Not sure how the Tesla stuff differs but apparently it does. I assume though that the tyre would be a write off if you used any sealant since you would never be able to clean it out due to the foamIf you don't want/can't plug the problem then wouldn't something like this be much cheaper than that one from Tesla?
Holts 400ml Tyreweld Puncture Repair | Wilko
Have used the bicycle equivelent and it was very good. That is why I got it. Obviously you have to be able to find the source of the punctureSeen one of those earlier. Have you used one? I wasn't sure how easy or effective that would be.
They need the foam lining to reduce road noise. Something specific to EV as, in an ICE vehicle the hum would be drowned out by the hum of the engine.The tyres have a foam lining I believe that interferes with that stuff. Not sure how the Tesla stuff differs but apparently it does. I assume though that the tyre would be a write off if you used any sealant since you would never be able to clean it out due to the foam
