No tech - no way (manual or automatic) to dim the rear view mirror?
Discussion in 'Model S: Interior & Exterior' started by zentage, Dec 29, 2014.
  1. zentage
    zentage Member
    Norway
    In all my old cars I've usually had a small fold tap to pull/push manually to dim the rear view mirror (the one inside the car and above the center console).
    I know the model s dosent come with auto dimming unless you get the tech package, I was fine with that. But I did expect a manual function to dim the mirror.
    What gives? anyone else out there non-tech that has noticed this?
    Manually dimmable rear view mirror comes standard on just about all other brands I know of, it seems with the model S you either get the tech for auto dimming or nothing?
    Am I missing something?
  2. mknox
    mknox Well-Known Member
    Toronto, ON
    I could be mistaken, but I believe the interior mirror is auto dimming on all models. Perhaps it is only the exterior mirrors that have auto-dimming if you get the tech package.
  3. zentage
    zentage Member
    Norway
    mine surely does NOT feel like it's auto dimming, during these dark cold winter days I have several times felt the need to lower my head to get the light beams reflected from the mirror off my eyesight.
  4. mknox
    Toronto, ON
    Interesting. If you look at the back of the mirror (the part facing forward) there will be a small opening for the forward ambient light sensor IF the mirror is auto-dimming. That would be one way to tell.
  5. zentage
    zentage Member
    Norway
    yup I have the sensor, which made me think it has the auto-dimming feature. Maybe mine is just coincidently faulty?
  6. Glitch
    Glitch Member
    The Netherlands, Europe
    You can clearly see if it is is diming as the mirror will not be fully dimmed but the outside ring of the mirror will be undimmed always and the innerside of the mirror should dim.
  7. jerry33
    Texas
    I can see the ring quite clearly in mine, but it stopped dimming some time ago (it gradually got worse until dimming was zero). The hatch sunscreen works well to dim the rearview mirror, but I have to put my hand up to block the driver's wing mirror. The SC didn't seem particularly interested when I mentioned it, but I haven't pressed the issue either.
  8. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    How can a service center not seem interested in a defect that you've brought to their attention? I'm curious about how that happens. When I give my service center a list of concerns, they address all to my satisfaction. That is their primary job function.
  9. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Right. Seems odd. I've given my SC a list of things to look at, and they go through every item. Even if they don't address something, the provide some justification (considered normal, within tolerance, etc.). I can think of no justification for ignoring a completely malfunctioning component. Sounds like a communication issue where your concern didn't make it onto the car's "to-do list" while it was in for service. Not that this excuses it, of course. I always verify everything I want looked at made it onto the visit's paperwork (my SC emails the document after I drop the car off).
  10. Txy
    Txy Member
    Earth
    I've read quite a few reports of the auto dimming gradually getting less and less effective as usage goes on.
  11. Gizmotoy
    Bay Area, CA
    It's a common failure for the technology. It's essentially electrifying a thin conductive layer of gel that darkens when current is flowing through it. The gel degrades chemically over time, reducing its efficiency. Certainly it shouldn't be failing in a car that's, at most, 2 years old, though.
  12. golfski
    golfski Member
    Seattle, WA
    I can confirm as a non-tech owner, the rear-view mirror is NOT auto-dimming. There is a "flip" tab that allows you to flip it up or down to a dimming/reflective view. My VIN is 42XXX.
  13. jerry33
    Texas
    My experience has been that they do things you specifically ask, plus they do things that Tesla says are due for your particular car or that they find during one of the test drives. I didn't do a specific request to look at it, just mentioned that they no longer worked as well as when they were new (at the time they hadn't gone out completely). At the Dallas SC, they are short staffed, totally overworked, and are in a way too small facility. So I consider this more my fault than theirs.
  14. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I've only had my girl for 3 months (today, as a matter of fact) and I have already noticed that the interior mirror does not dim as much as when new and dims much slower than the side mirrors. At first, it got way too dark-couldn't see a thing. Now it barely dims at all. I thought it might just be me, but I think a visit to the SC is in order.
  15. mknox
    Toronto, ON
    Interesting. I have an Auto Dimming mirror that I removed from my 1994 Eagle Vision TSi before I sold it to re-install in another car I have that didn't have the feature. It still works like new. Both of the interior and exterior mirrors on my almost 2 year old Model S are also working just fine.
    I think that Tesla Service would be all over getting broken ones fixed. Isn't having some sort of dimming capability on the mirror, either a manual flip switch or electronic some sort of compulsory safety feature? I don't think I've seen a car in the last 30 years that doesn't have the feature.
  16. zentage
    zentage Member
    Norway
    well, mine does not have a flip tab, perhaps they've made Auto dim standard with the "Sensor upgrade", my car is a bit newer than yours, VIN 51XXX (post sensor upgrade oct 14)
    However, it dosent seem to dim auto either :/
  17. Gizmotoy
    Bay Area, CA
    Clearly it should do one or the other. Sounds like its either malfunctioning or a mistake was made. Either way, time to involve Tesla.
  18. AmpedRealtor
    Buckeye, AZ
    I've heard of only one report.
  19. jerry33
    Texas
    I know of two. Mine and one other.
  20. Brass Guy
    Brass Guy Member
    Holbrook, MA
    My non-tech also has the flip tab. Mine is in the 17xxx range though. Sounds like a factory mistake to me.
