Noise level
Discussion in 'Model S' started by mikeg561, May 18, 2015.
Tags:
  1. mikeg561
    mikeg561 Member
    huntington beach, ca
    Hello Everyone!
    I am new here. I did a search for this question before asking here, but did not have any luck finding an answer. So I hope I am not repeating a question already asked.
    I am seriously considering a model S. I currently drive a Lexus LS460 and one of the things I love about my current car is how quiet it is- even when driving on the highway.
    How is the Model S with street/highway noise? Has there been any tests done to compare noise level with a DB meter?
    Thanks!
    Mike
  2. artsci
    artsci Sponsor
    Timonium, Maryland
    There are many threads on this topic, including some that I posted. I suggest you use the search function to find them.
  3. chriSharek
    chriSharek Member
    Sarasota, FL
    First of all, welcome. I haven't had much luck searching these either.
    If you are asking this question about noise, then you have got to go drive one. There is no question that MS is quieter than any other car you have ever driven. Not only that, but the lack of a transmission makes for the most silky smooth drivetrain. Go drive one!
  4. JPP
    JPP Active Member
    SF Bay Area, CA
    Subjective data--my wife drives a 2011 LS460 with Bridgestone Turanza Serenity tires. My S is quieter overall but you notice the road/tire noise more (I'm driving on the OEM Goodyear's). You overall will enjoy the ride more and be less fatigued in an S. And, if you read my sig, you will see we have ordered an S70D to replace her LS next month when it goes off lease.
  5. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    I test drove a Model S 85D and I must say, it's very quite. There is a slight motor wind in the beginning, but once you get up to speed, it's gone. This might be caused by the induction motor. I have driven other EVs and they do NOT exhibit the low speed motor wind noise.
    The rest is just road noise and wind noise which is very little even on the highway. The model S I test drove had 21 inch rims and I heard they are noisier than the 19 inch rims. People have also complained about the panoramic roof as a source of noise after a few thousand miles due to the seal.
    It seems like consensus is:
    1) Low speed motor noise possible
    2) Panoramic roof wind noise once seal are worn
    3) Road noise from 21 inch rim is higher. Get 19 inch rims and put michelins mxm for minimal road noise
    4) Air suspension does not seem to help with road noise, just allows you to get up or off steep driveways.
    5) Static noise from speakers if sound system are not properly isolated. Not much you can do here other than bring it back to tesla.
    Others feel free to add.
  6. ibdb
    ibdb Any excuse for a road trip
    Puyallup, WA
    From Edmunds.com
    2011 LS460
    2012 Tesla Model S
    Edit: @70mph readings got cut out when posting the first time.
  7. mikeg561
    mikeg561 Member
    Thank Ibdb! That is very helpful. And all of the other comments have been great!
    So the difference at 70mph is about 3 db. According to one site I looked at, 3 db falls into the "Barely Perceptible Change" range.
    Thank you everyone!
    Mike
  8. Knobby
    Knobby Member
    Ottawa, ON Canada
    Sound level @ idle 39.2 dB .. how can that be? The car absolutely makes no noise at idle. Maybe the AC was on.. hah!
  9. ibdb
    Puyallup, WA
    A library is said to be about 40 dB.
  10. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    39.2 dB was for Lexus LS 460. Tesla was 35 db, which would be perceived as less than half as loud as Lexus. That's basically background noise. dB charts list 30dB as "whispering" or "whisper in quiet library at 6 feet" Possibly the AC fan or just outside noise.
    Normal conversation at 3 feet runs 60 dB.
    Difference between 58.2 dB and 61.2 dB in Ibdb's charts would be perceived as twice as loud, but both are about at the threshold of normal speech.
  11. No2DinosaurFuel
    how is full throttle any different from cursing for the Tesla? Noise should be the same if not less. Is the noise coming from the tires? If so, I would expect 70mph to make more noise then. There is something fishy with the data. My Spark EV makes 0 noise during acceleration... unless I am burning rubber on the cheapo ecopia tires. Otherwise, 15-60mph is same if I light throttle it or full throttle it. I test drove the 85D and the noise is definitely noisier at 70mph cursing than accelerating to 70mph.
  12. Majerus
    Majerus Member
    Illinois
    There is a whine at full throttle.
  13. mikeg561
    mikeg561 Member
    I assume a lot of the noise would be road noise.....nothing to do with the "engine."
  14. kanylbullen
    kanylbullen Member
    Stockholm, Sweden, Sweden
    The dual motor models have considerable more acceleration noise - coming from the front motor obviously.
  15. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
    I wouldn't say it's considerable. Having owned a 60 kWh RWD before and a P85D now, I can describe the front motor sound as a faint whisper.
    Now, about that Lego piece that my son's tossed somewhere in the car. I can hear that (and that alone) rolling around every time I make hard turns or launches :)
  16. kanylbullen
    kanylbullen Member
    Well, I hardly ever notice the noise anyway thanks to the premium sound system always being cranked up to unhealthy levels. The smaller frunkspace is definitely a bigger issue for me, but never the less I absolutely love my 85D!
  17. Ed Chan
    Ed Chan Member
    Palos Verdes, CA
    #17 Ed Chan, May 19, 2015
    My dad has a '08 LS460L... I have the S85. My ears tell me that the LS460 is actually quieter, especially at highway speeds. The Tesla lets in quite a bit of road and wind noise, and I'm sure the Lexus has more insulation for the cockpit. The Tesla isn't loud or annoying at 80mph by any stretch, it's just that the LS is really really well insulated from road and wind noise and the engine is really really quiet.
  18. jerry33
    Texas
    The Model S often seems louder because of the difference between the noise level when it's stopped and the noise level when it's traveling. Road surface makes the biggest difference in how loud it is (at least in my car).
  19. liuping
    liuping Active Member
    San Diego
    I believe the newer models are quieter that some of the earlier VINs,.
    I had a late '14 P85 loaner with 21" wheels on my last service, and it had noticeably less road and wind noise at highway speed than my November 2103 S85 with 19" wheels.
  20. russman
    russman Member
    Some of the higher end Lexus/Mercedes/BMW have less noise from more insulation, dual pane glass, etc... But I believe the newer S have more insulation now too.
