  • The final cut of TMC Podcast #29 is available now with topics time-stamped. We discussed the Tesla Cybertruck's expected 1 MW Ultra-Fast Charging capability, the Tesla Semi Delivery Event, the coming Model 3 refresh (project "Highland"), and more. You can watch it now on YouTube.
Noise while braking
talkingevs
GO AVS! 2022 CHAMPS!
Jan 28, 2018
463
229
Las Vegas, NV
So while out and driving today I noticed a noise that happens Everytime I come to a stop. At first I thought it was the AC as it sounded almost like water or some fluid in the dash area. However, I eventually figured out it has to do with braking. It only occurs when coming to a slow stop and only the last very but before stopping. If I brake harder, you don't hear it. My car only has 17000 miles and is a year old, so I find it hard to believe I need new rotors or brake pads. The noise is really hard to describe but it's not a screech. Anyone else have something similar or know what it could be? It got cold this week so maybe that has something to do with it? But then again, I usually play music so wouldn't hear it.
Turn regen on low and do 5-10 firm stops or slow-downs from above 30mph (can be faster just be safe). No need to trigger ABS but the point is to clear the surface of anything that may have accumulated or picked up. You could also spray down the wheels with a hose to knock anything loose that might be in there. If you parked next to sprinklers or had rain, there's rust that builds up between the rotors and pads. In normal cars it'd wear off within a few stops but in our cars with regen it can take weeks...
Reactions: 5_+JqckQttqck
