Non-PUP Front Door Opening
Discussion in 'Model X: User Interface' started by fengshui, May 26, 2016.
  1. fengshui
    fengshui Member
    Santa Barbara, CA
    Without PUP, the driver's door does not auto-present when you approach the car. Is there any way to cause the door to present without pushing the driver's side door handle? Does a double-press of the key-fob center cause door opening, or does that just unlock the door(s)?
  2. loganintx
    loganintx Member
    Austin, TX
    Auto Present is only available with Premium Upgrade Package. I believe you can make the doors close with the FOB but not make the driver's door open with the FOB
  3. fengshui
    fengshui Member
    Santa Barbara, CA
    Yes, but I'm explicitly not asking about Auto Present. I'm asking if there is a way to remotely trigger door presentation without PUP, or if you can only trigger the door presentation with the door handle or the center console.
    Okay. There are lots of cars in the wild now without the PUP. Let's let someone who has one share their experience rather than speculate.
  4. ModelS8794
    ModelS8794 Member
    PA
    I do not have the PUP. To open the front driver and passenger door, I must press the door handle from the outside, or use the handle on the inside, or use the touchscreen. No other way to have the front door present itself; no functionality on the key to open the front doors afaik.
    Related: If the doors are open, single pressing the top of the key will shut the driver and passenger front door and lock the car. Touching the brake pedal will shut the driver door but not the passenger door.
  5. loganintx
    loganintx Member
    Austin, TX
    Just as I believed. Speculation game strong!
  6. fengshui
    fengshui Member
    Santa Barbara, CA
    Thanks. That's what I thought too, but I saw a recent reference to opening the driver's door with the fob, and wanted some clarity. Too bad, as being able to double-click the fob and open the door would be pretty nice, and would still allow for the PUP purchasers to have the additional feature of it opening with no interaction at all.
    Out of curiosity, if there are any owners with PUP here. Can you open the driver's door remotely using button presses on the fob? I've heard some PUP owners have disabled the auto presentation. When you do that, does your car then act identically to the non-PUP behavior above, or is there another option you have to open the door?
  7. elguapo
    elguapo Member
    Maryland
    I have PUP and there's no way to open doors without auto present or pushing. Driver door auto closes when you walk away, no need to touch fob.
    It seems like they can change all of this with software, if they want to.
  8. Merrill
    Merrill Active Member
    Sonoma, California
    I'm I correct that if you have pup you still can disable auto presenting of the front drivers door.
  9. fengshui
    fengshui Member
    Santa Barbara, CA
    I guess the person who told me that you can open the door with the fob was just wrong. Sounds like it's either full auto-present or door handle push only. Thanks everybody! You all have been very helpful.
  10. elguapo
    elguapo Member
    Maryland
    @Merrill You are correct. With PUP, you can disable auto presenting door. I love it, so I keep it on. Many feel differently...
  11. Merrill
    Sonoma, California
    Thanks for that info, not sure how I will use it.
  12. Dazureus
    Dazureus Member
    Michigan
    The new software update allows you to open the drivers side door by unlocking with the key fob, but the functionality is tied to the auto-presenting door.
  13. Marcos
    Marcos Member
    Oakland, CA
    After the new update, double clicking on roof of fob opens the driver's side door. I have PUP, so can't say whether that functionality works for everyone.
    My auto-present is still broken.
  14. KristianW
    KristianW Member
    Trondheim, Norway
    Has anyone without the PUP tried this after the new update?
  15. JimVandegriff
    JimVandegriff Member
    Trinidad, CA
    Did not work for my non-pup. I'll try it again under different conditions later today.
  16. elguapo
    elguapo Member
    Maryland
    I can't imagine they'd enable the auto open from FOB for non PUP. PUP buyers would certainly have an argument that they bought something that's now effectively available to everyone (but not completely since you need to click fob vs true auto present). I wouldn't care, but just saying...
    The auto close for all doors is really useful and, as a bonus, looks really cool.
