"wheel whore!" LOL
Not sure what TE37 is but I'm familiar with the spacers concept. Do you have any links to what you're saying may be required to fit the 9.5" 40mm offset wheels onto the front? Good luck with your attempt. I'm trying to make a decision this week if possible otherwise I may have to put this off some. Thanks!
Volk TE37 - only the most JDM-sweet wheel ever made. I see no reason an 18" wheel wouldn't work on Model X, the front and rear brake package isn't that big, 355mm rotors with multipiston calipers fit under a LOT of sweet aftermarket wheels and the X uses a nice relatively low offset that helps with caliper clearance. My 355x35 4-pot Stoptechs on my M3 fit easily under an 18" wheel, and can even fit under certain 17's. Unless they have stuck some part of the suspension inside the wheel barrel that I haven't noticed. I'm sure somebody on here knows definitively, but I always have to prove these things to myself. If there's room for snow chains there has to be room for a 275 on a 9.5 with the right offset, I mean, look above, there's a guy running 10.5's all around with the 285/35-22 OEM rear tire size.
Which all begs the question, which mud tire should I run on my 18" volks, lol
For these cars might need to use a spacer made for the Civic Type R, maybe, not sure what's out there that will work with the 64.1mm hub and a 5x120 bolt pattern. Or there might be a tesla S/X spacer available I'm not aware of yet because i'm just idly thinking about this stuff and have done zero research or actual shopping because if wheels arrived at the house before the car I would be murdered and sold for parts
edit: H&R makes a wheel spacer for S/X. There, soup
