charlesj
Thanks. Interesting. What I have not, before the installation are two 100A breakers in the main panel feeding two subpanels in the house, main floor and 2nd story. Solar 20A breaker is tied into the 2nd story subpanel. That solar power finds its way to the main floor at the main panel.That's not how the 120% rule works, the size of the loads don't matter. What matters is the size of the sources of power feeding the bus in the panel. For the utility, the size is the rating of the breaker. For inverters (like solar and battery), the size is typically also the rating of the breaker but may be a little less (details omitted).
So if you have a 200A bus with a 200A main breaker, you can back feed up to 40A of breakers of solar/battery. With a 225A bus with a 200A main breaker, you are up to 70A of allowable back feed. Or with a 200A bus and a 175A main breaker, you are at 65A.
Cheers, Wayne
Now with the 2 PW, another panel will be installed after the Gateway with two 100A for the two subpanels and the 2 30A for battery.
My quandary is the downsizing of original 2-100A in the main panel not to a single 200A but to a 150A after pressure on the designer as he wanted only a 100A as the breaker
The main breaker will see the same original 2-100A loadwise. Same ampacity as before.
