Nose cone is now loose
Discussion in 'Model S: Interior & Exterior' started by artsci, May 13, 2013.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    After removing the nose cone a few times over the past several days, the clips no longer hold it tightly in place. Believe me, strong gust of wind from the wrong direction might make it fall off. All of the clips seem ok but perhaps a bit of very small wear is the problem. I have a solution but it will make easy removal of the nose cone much more problematic.
    Anyone else having this problem with the nose cone?
  2. Laurent
    Laurent Member
    SF Bay Area
    Tried duct tape?
  3. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Artsci,
    For my edification, are the clips attached to the nose cone or separate items? I am wondering if this is this a problem with your modified nose cone (with all the gizmos attached) or if your original nose cone would also have the problem?
  4. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    I'd ask Tesla Service for some replacement clips to purchase. I wouldn't do a workaround, I'd want the original clips.
  5. Tommy
    Tommy Member
    The great OC
    On the chance that maybe user removal/replacement fatigue has set in: The lower clips fasten into their own holes which are adjacent to the decorative grid holes; it is easy for the clips to be placed in the wrong holes. The only way to avoid this is to be on your hands and knees and visually make sure the clips are fastened correctly. Doing it blindly will invariably have the clips in the wrong holes; I've done it and Tesla has done it. Between me and Tesla, my nose cone has been off about a 1/2 dozen times; it was loose two times due to the bottom clips being not being in their correct holes.
    Hope that's the cause as having to remove the nose to access the auxiliary battery posts means this will be a wear item.
  6. artsci
    artsci Sponsor
    Timonium, Maryland
    What I called clips are actually tabs molded in the back of the nose cone plastic that snap into slots in metal surround. I think plastic fatigue is a way to describe the problem. The tab at the top center back of the nose cone is the one that's doesn't hold. But I found an easy fix tonight. I attached binder clips to the back of the tabs where they poke through the metal surround. Now it's very tight. This will make it more difficult to remove the nose cone, but that's ok with me.
  7. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Is this your original nose or the new one you bought?
  8. artsci
    artsci Sponsor
    Timonium, Maryland
    It's the new one/replacement I bought for installation of the Blinder laser jammer transponders. It's been handled quite a bit which is probably the issue. But with my fix it's now tight as a drum.
