Not able to charge with Mobile Charger
brewster
464
104
Warrnambool. Vic. Australia
Over the last day or 2 I hace tried to put some charge into my Tesla. It just so happens I had a software update waiting so on the off chance that may help the situation I tried again to charge at home. 'Red Light' fault still apparent. On close inspection of the cars' port, it appears one of the pins looks different. The top left pin looks like its missing an outer covering - therefore no connection? What do you think?
jamesgo
214
125
Australia
Looks like mine and it's the same. Did you get a error message on the screen or a red light on the charger? My mobile charger stopped working and I had to get it replaced.
meloccom
Moderator Aus/NZ
Feb 11, 2008
2,306
1,195
Sydney Australia
Worked fine in a local destination charger, so mobile charger is stuffed.
Is it repairable - I believe this is the original mobile charger used in Australia circa 2015?
Plug it in and press the reset button on your Wall Connector and it may stabilise as green. If successful about 10 seconds later the car will see the power and start charging. This is what mine is doing at the moment. I contacted Tesla and they said they are not repairable but the Service Centre will accept a broken Charge Connector for recycling.
brewster
464
104
I have shifted residence and don't have my HPWC installed anymore, so I was just relying on my Mobile Connector for charge. Warrnambool Supercharger gone now of course. I intend to reinstall in my next residence although I'm hoping to get a Model Y when available so I guess my HPWC won't be of any use anymore. My 3 phase 5 pin 20amp, 32amp will be redundant with the Y as well I assume.
Thanks Meloccom.
jamesgo
214
125
Australia
Thanks Meloccom.
?? The HPWC should work fine with the Model S, X, 3 or Y, in Aust, they're all the same Type2 connector on new deliveries.
QBN_PC
181
151
Queanbeyan
Does Tesla not cover such things under Warranty? And if you're buying a Model Y you'll get a new UMC with it anyway (not that you'll want to make do with only one UMC for two cars!). The wall chargers and UMCs are identical. The plug only varies for DC charging (e.g. superchargers, NRMA, Chargefox and Evie Networks rapid chargers).
paulp
2,603
1,167
Adelaide, Australia
The connectors are covered for the same warranty as the car, although I suspect Brewsers has expired.
brewster
464
104
I'll be selling my 2015 P85D when I get my Model Y.
So my destination charger will still work for the Model Y - great!!
And so my Maxicharger for 3 phase will be fine as well - great as well !!
I wonder if I can hang on without replacing my mobile charger and just use the Warrnambool destination charger for around town - hmmmmm.
paulp
2,603
1,167
Adelaide, Australia
Thanks Jamesco - great news for me ... with me just recently replacing my MCU1 I thought my Tesla experience was coming to an untimely end.
Really, I could never go back to ICE!
Any reason you cant connect your hpwc with an extension cord hard wired and turn the amperage down to 10 amps? It can then also be mobile.
paulp
2,603
1,167
Adelaide, Australia
I didn't know that was possible. I'll be getting my HPWC connected to my new home soon, electrician has just started the initial wiring.
Thanks paulp.
Just to clarify, you turn the dip switches in the hpwc to 16A breaker which delivers a maximum 10A, and select 10A inside the car.
