Not able to connect Tesla's Wifi to home network?
duBois
93
0
Eindhoven
Hi,
I'm experiencing problems when connecting my MS Wifi to our home network. BGN network, SSID visible, european, WPA/WPA2 personal password. AES+TKIP.
Even with all security off (open network) the MS will not connect to it.
Any clues or tips?
Crispix
311
97
San Diego
Can the car connect to other wifi networks? Make sure the car wifi at least works.
If so, I'd suggest messing with the band settings, turn off B and just try G, for example. You might be able to try different channels on the wifi access point. Maybe the car is too far from the access point?
roundy
New Member
Sep 17, 2013
4
4
United States
I have the same issue. Unable to connect to my 802.11N home network. I've tried forcing 802.11g and turning security off, but nothing works. The car will see all the local networks (except for 5.0ghz N networks) and recognize that some require a password. But after I enter the password, the connection will fail and I get the message to "Check the password."
andrewket
5,704
1,525
Try changing your password to exactly 8 characters long and don't use any non alpha numeric characters. I've seen a similar problem before and that was the solution.
The fact that it doesn't connect without encryption shoots a hole in this theory, but it's worth a try.
NielsChr
266
3
Denmark
just a guess - your wifi router typical uses a fixed channel for your wifi, try change this channel to a different - offen this helps in situations like yours.
some equipent does not like specific channels - so changing to another could help compability.
Aug 14, 2012
156
10
If you have a smart phone that allows wifi tethering, you may want to see if it connects with it. Also, how is the bluetooth, does it work?
duBois
93
0
Eindhoven
Bluetooth works flawless, also the MS does connect to a wifi tethered iphone. just not to my WiFi home network... It does connect to other Wifi networks belonging to my company's .
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
You also can search Google for NetStumbler. Its a wifi security (reveal) tool. Version .9 ran only on Win XP. don't know about more recent version.
It will tell you about wifi routers running in your neighborhood. Once you see what channel and what SSID they are running on, you can move your AP to a different channel.
This way your change your AP to use completely different.
The explanation of your problem sounds a lot like you are competing head on with others running on the same channel.
Highly unlikely but, someone might be copying your SSID. If they are, they are messing with you. Even though you have a different password, your system is being stepped on.
EU#536
New Member
Jun 23, 2012
2
0
I have the exact same problem. Have you found a solution? I would be happy to know. I have tried all of the above, nothing works. The signal in my garage is good.
Hi,
I've had the same issue. What I had to do to get things working was allow 802.11b on my access point (Apple Airport). I have a feeling the NIC in the car is only 802.11b. It's made by a company called Parrot but that's all I've been able to figure out. If I figure out the model, I'll post it.
-- Andy
RandyS
Fan of Elon
Jul 8, 2012
692
887
San Diego
Here's the issue I had...
On my wireless access point during the setup process, I typed in a "passphrase" and in turn the access point generated a hexadecimal "key" from that passphrase.
Once set up, for every laptop or device I have connected to my wireless network in the past, I have used the hexadecimal "key" as the password on the laptop when connecting to the wireless network.
In the case of the Tesla, it would not connect in this fashion, but as soon as I typed in the entire original "passphrase" then it connected right away...
mitch672
1,861
13
Stoughton, MA
Just received and installed 5.8 (had 4.5)
I have multiple Wifi routers in range, and I can't get the Model S to join.
Tried rebooting the center screen, didn't make a difference.
Is there any trick to getting the car to connect?
Mitch
dirkhh
Middle-aged Member
Jul 7, 2013
3,638
126
Portland, OR, USA
Not really. Can your car see the access points? What does it do when you try to connect? We need a little more data to help.
mitch672
1,861
13
Stoughton, MA
Yes, it sees both access points. States it can't join "network name"
Please check the password. I have multiple iPhones and iPads joined with the same password..
