For the owners that live in Northern Virginia, what did it cost to have a NEMA 14-50 outlet installed? Are there any other alternatives? Also, if you used an electrician, is there anyone you can recommend?
Thanks!
Thanks!
I live in Northern Virginia as well. I have configured my model 3 last week and expecting delivery 3-6 weeks. I will probably have electrician coming to my home this weekend. I will share quote once he comes.For the owners that live in Northern Virginia, what did it cost to have a NEMA 14-50 outlet installed? Are there any other alternatives? Also, if you used an electrician, is there anyone you can recommend?
Thanks!
It would depend on your usage. the 14-30 is 22miles per hour, right? Calculate how many miles you typically drive in a day, and how long you would need to charge. If you drive 300 miles a day, and are only home for 10 hours, then no, the 14-30 will not be enough. If you drive 50 miles a day, and are home for 10 hours, then yes, the 14-30 will be more than enough.I live in Northern Virginia as well. I have configured my model 3 last week and expecting delivery 3-6 weeks. I will probably have electrician coming to my home this weekend. I will share quote once he comes.
Another question I have is, I have finished basement and electricity panel little far away from garage (around 25) feet so for me to do NEMA 14/50, I have to break cut drywall and pass cable from panel to garage. Another option I have is, I have NEMA 14/30 in my mechanical room for additional dryer which I am not using. My mechanical room is right below garage and unfinished from where I can easily extend 30 A cable to my garage. Do you think its worth to do 14/50 over 14/30 for additional 8 miles/hour extra charge?
I for the quote from electrician. For extending 14/30 from mechanic room to garage above is 340. This would require 50-60 feet of cable to due to location where I would like to install outlet in my garage. For 14/50 it was 900 as we need to create new circuit along with new wiring from the panel. My daily commute is around 30 miles and may added up adding another 20-30 files couple of days of the week.
I think I will go with extending 14/30 from mechanic room to garage upstair.
Hi his name is Dave and his contact number is 703-851-1260. I would highly recommend him. I finally decided to go with NEMA 14/50 with new circuit from panel. We used cable which can support 60A but installed with 50A breaker. This is just in case if I want to use wall charger.Thanks for this info. Do you mind sharing the info for the electrician?
Sometimes I feel Viirgibia is worst state. There is no state rebate for any thing related electric vehicle and we still have to pay personal property tax.Guys this is what I would recommend to do as noted above. You can gain another 33% charging when you get a wall charger in the future. Then it is a simple swap of the breaker and change out the plug. The #6 is the correct size for the wall charger.
I'm going with the wall charger and running the number #6. I would like to be able to get a quick charge should I get stuck in a bind.
Also living in Va we do not benefit from the referral process for the free signature wall charger because of VA law blocking it.
I did this based on the Model S charger info. I assumed it applies for the 3 also.
Thanks. I actually had it done last weekend for $1000. I had a NEMA 14-50 outlet installed (with 6 gauge wire) but no new panel . He was able to add in a 50A breaker into my current panel by making some of the existing breakers into tandem breakers. We have 200A coming into the house, so he mentioned that there was no need right now to add a new panel.
Did you get your VIN assigned? I have not yet received VIN. I configured red aero eap on 02/11.
