Was just reading a write up of the 2018 Mustang GT. Also a $35k car but does 0-60 in under 4.0 seconds. Faster than a $90k Porsche 911.
Disappointing that Tesla couldn't get the base times a little closer to a performance car range. Even if/when the P version of the model 3 comes out, it will likely cost at least $15-$25k more to get in that range.
At 5.6s, the base model 3 is 40% slower to 60mph. It doesn't matter if the EV torque is instant...the ICE mustang will have a faster 0-20, 0-30, etc. and will pull ahead within 2-3 seconds in track mode, certainly feeling much faster in real world driving than the Tesla.
Realize they're not really good comps (sedan vs. coupe, "luxury" vs. non-luxury) but come on...
In everyday driving situations, any electric car with 1/2 the GT's power to weight will dance around it.
Why? Three things. What is necessary to ever see full output, 'area under the curve', and inertia (both driveline and air).
Full output of the Coyote is about 6,750 rpm. How much power does that Coyote make at 2000 rpm when you're actually driving? Roughly 100-110 rwhp. Nada. You need to spin the crap out of the Coyote, it doesn't make 50% acceleration until 3500rpm.
Related to that is area under the curve, or how much average horsies does it muster? Well the 10-sp trans is there for a reason. In order to keep above 75% of engine output, you need to shift a lot. Power climbs with RPM.
The inertia is because at 2000 rpm the moving parts AND the air is moving slow. You must apply power to get them to move faster. This is parasitic. The more air velocity you need to acquire and more RPMs you need to build take HP.
What happens when you add up all these factors? If you are cruising at 50 mph, and just floor in it a manual Coyote GT, virtually every car made will get to 70 mph faster, even other stick cars. 205mph ZR1 stuck in 6th at 50? Bogging at 1,500 rpm at 50, the ZR1 will hit 70mph in a leisurely 5.1 secs. The Coyote? 9 freaking seconds?????
This is what happens when all 3 conspire against you at once. Poor low RPM output, poor area under the curve, the inability to get the air moving. Why is the ZR1 with tall gears any better? The inertia and area under the curve are attenuated by positive displacement forced induction.
EV have a nearly flat power curve. They punch right at 0 RPM and hold it until the PCM turns it off. Inertia of air is gone, but rotating mass is smaller too.
If an EV 'gets the move' on a 2018 Coyote, it will take awhile for the Stang to catch back up. And that's a small EV. The Model 3-220? It probably won't catch it before the 70 or higher.
But we will see.
