I noticed a few days ago with the car only plugged in while checking on the app the snowflake disappeared and there were 10 more miles of range. It was about 10F outside and the car was set to time charge in the early morning in about 5 hours. I have a Juicebox charger on wifi where I can see the voltages and amperage and noticed the car was drawing about 10amps @240 volts during this time. Normally it is set to charge at 40 amps. No charging was indicated. After about 30 minutes the current draw from the charger stopped, the snowflake was gone, the blue bar was gone and there were about 10 more miles on the car mainly due to the blue bar now being green. I went to sleep so not sure if it cycled on and off.
I did the same thing the next night on my other model 3 and similar results.
So it appears to me the car was actively warming the battery by being plugged in but not charging. Both cars have 2018.50.6. I have not noticed this behavior prior but this was our first really cold spell. (For NJ!). I know the car does not have a direct battery heater, it was not charging so where was the current going? My suspicions are the current was going to motor using the "zero torque mode" to heat the battery coolant.
Anyone else see this behavior?
If so it is good to know you can heat the battery with just plugging in. I don't charge every night but could plug in to avoid the snowflake and very limited regen in the morning.
