Now Shipping: Custom Tesla Roadster 2-Piece Slotted Rotors
Discussion in 'Roadster 2008-2012' started by wiztecy, Jan 16, 2015.
Tags:
  1. titaniumdave
    titaniumdave Member
    Portland OR
    Greg,
    Yes, clamp the brake down hard and this should set the pads in the correct location.
  2. gregd
    gregd Active Member
    CM98
    {sigh}
    I unfortunately have to report that a re-application of the goop to the pad did not work. The mechanic said he did some research on his own, and applied some to the piston as well. Dried and re-assembled. Pushed on the pedal to set the piston into the pad, then let it sit for a few minutes before driving it. He said that it worked, but on the way home I tried it, and the clacking was definitely still there. In fact, it seemed to require less braking force than before to cause it.
    I'm still not quite sure that he got the idea that the goop needs to be totally dry. He said that it "would get hard", so I'm thinking he thought that totally hard was bad, and still assembled the brakes too soon. To those who have succeeded, drying totally hard is what we want, right? Even if he used a heat gun on the pads, I doubt it was used on the piston, so perhaps that's where the error was? The car was only driven a few miles (home to shop) before being taken apart, so the front brakes were likely still stone cold.
    I asked him what he would do if this didn't work (this was before the test drive), and he said that he was thinking to swap brake pads with the driver's side (the ones that are working) in order to see if perhaps the pads or rotors were at fault. I'd strongly prefer not to touch the left side, since it's working.
    Any last thoughts?
  3. titaniumdave
    titaniumdave Member
    Portland OR
    Hmm, it does not matter if the goo is on the pistons or the pads, same interface once installed. From my experience the longer they sit before you drive the better. Make sure the pin springs are tight, lots of tension between the pins and the pads.
  4. ShawnA
    ShawnA Supporting Member
    Edwardsburg, MI
    Hi Dave,
    I received mine today and they look great...
    Me or my Tesla Ranger will install them...
    In layman's terms - the brake quiet goop - Is it supposed to be a high temperature adhesive?
    Or is it suppose to be a "textured spacer/shim filling the space between the pad and piston?"
    Or is it a "sound deadener" to keep the parts from ringing or finding a resonance?
    I think this is the 3rd batch of the rotors.
    Is it this batch or 2nd batch that the pads were pre-broken in?
    Thank you, Shawn
  5. titaniumdave
    titaniumdave Member
    Portland OR
    Brake Quiet is high temp adhesive.
    This is the 3rd batch of rotors. Some of the 2nd batch of pads were pre-bed and looked dusty.
  6. titaniumdave
    titaniumdave Member
    Portland OR
    I still have a few set of rotors in stock from this batch...folks either didn't pay or chose to not get them for one reason or another. Let me know if you have been waiting to make the purchase, no waiting for brake improvement!
    Dave
    [email protected]
  7. Nvbob
    Nvbob Roadster 1256
    Just east of Lake Tahoe, Ca.
    We changed our rotors and pads a couple of weeks ago. Here’s the procedure our tech used:
    Apply the brake quiet to the back of the pads and set them aside to dry.
    Clean the rotors (Dave uses a soapy solution and a brush - they use Dawn, then rinse, and allow to dry) then with brake cleaner to get the shipping protectant off.
    We followed @strider’s instructions - Now Shipping: Custom Tesla Roadster 2-Piece Slotted Rotors
    Per our SC - Tesla recommends using blue loc-tite on both the 5mm rotor to the hub bolts and also to the 8mm Allen caliper to the knuckle bolts.
    Also, per our SC - The torque on the rotor to the hub bolts is 20 N/m and the caliper to knuckle bolts is 45 N/m
  8. gregd
    gregd Active Member
    CM98
    Hi folks, an update...
    I'm back at the shop. We compared the new Gloc pads with the original ones, and find the new ones are definitely smaller, which is the root cause of them rattling. Also see a lip on the outside edge, where the pad is hanging over the edge of the rotors by about a mm or so.
    The thought is to weld a shim on the side of the Pad so they will fit more snugly, and grind a camphor on the outside edge. But, shouldn't these have fit as-is??
  9. titaniumdave
    titaniumdave Member
    Portland OR
    I am corresponding with GLoc about the backing pads now. More info soon I hope. The outer edge hanging over the rotor is not an issue, it's common for aftermarket pad manufacturers to put more material on there pads to make sure they have coverage for all applications. This material will just fall off with no negative effect since it's on the out side edge and will not interfere with the pad or caliper removal.
  10. twiersum
    twiersum Member
    canada
    Can anyone grab a few measurements frim your stock rotors for me?
    How thick is the face plate where studs go through. How wide is the back of the rotor hat where it goes over hub?
    Thx
  11. titaniumdave
    titaniumdave Member
    Portland OR
    Hey there,
    If anyone has problems with the pad rattle, please contact me at '[email protected]' I have 3M high temp adhesive that will be easier to use for the front pads than the Brake Quiet. I can ship out patches you can put on the back of your backing plates to help keep them tight on the front pistons in the calipers. All pads that will be sent out in the future will have the adhesive already installed and all you will need to do is pull the protective film off the back and slide the pad into place after you have retracted the pistons.
    Now the dust has settled, I still have 4 sets of rotors ion stock and ready to ship. Let me know if you want a set. I will be putting them on eBay next week at a higher price to cover all the fees but you can still get them directly from me at $1595.
    Thanks for all the support.
  12. titaniumdave
    titaniumdave Member
    Portland OR
    Here is a thread about Roadster lift adapter I made, folks were asking for them and I made a couple extra sets...email if interested.
    Simplified Roadster Lift Adapters
  13. twiersum
    twiersum Member
    canada
    Has anyone tried the EBC yellow or red pads? Supposed to be the best from the reviews I've read.
  14. titaniumdave
    titaniumdave Member
    Portland OR
    I'm not a fan but some folks like them.
  15. gregd
    gregd Active Member
    CM98
    A follow-up report: I had the mechanic scrape off the goop and installed the 3M sticky pads. Not sure why, but they worked! No clicks. Yea!
    Also to confirm slcasner's report that the brakes do get stronger after a bit of use, so now they feel slightly better than the originals were under the best of conditions. And, no rust to deal with. Thanks to all who helped get this right. Very happy now.
  16. titaniumdave
    titaniumdave Member
    Portland OR
    Fabulous, all pads will be shipped with adhesive in the future.
    Thanks for the help making all these sets better!
  17. bolosky
    bolosky Member
    I got these rotors around the end of 2016, and then sat on them until now for no good reason.
    They're light years ahead of the stock ones. Totally worth the money and effort. The car actually stops in the rain without pumping the brakes! It feels good rather than the usual range of lethargic to frightening.
    Thanks so much for doing this.
  18. titaniumdave
    titaniumdave Member
    Portland OR
    So glad to hear from another happy user. I still have rotors in stock if anyone wants to make their car safer.
    Dave
  19. Stefan T
    Stefan T Member
    Sweden
    I have picked up mine kit
    They looks great
    Only installing left
    I will take it some day when i feel i have time to do it
  20. Stefan T
    Stefan T Member
    Sweden
    Now have i installed my break rotors
    One of the old ones
    Repced with a new
    New compared with old seen from inside
    placed like this
    right rear (new) left rear (old)
    right front (new) left front (old)
    Right front installed
    They looks great
    It was not the best wether for test if the breaks is better after upgrade
    worked well with weat roads
