Nvidia unveils Tegra X1 'superchip' at CES 2015.
Discussion in 'Cars and Transportation' started by Benz, Jan 5, 2015.
  1. Benz
    Benz Active Member
    Netherlands
  2. Model 3
    Model 3 Active Member
    Norway
    Interesting wordings:
  3. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    The Drive PX looks like an interesting option to meet Tesla's needs. I found it interesting that NVidia pictures a BMW in its older Drive CX section.
  4. tdelta1000
    tdelta1000 Active Member
    South Florida
    Tesla Will benefit greatly.
  5. ORB
    ORB Member
    I've long wondered about the Tegra chipset than runs my Model S touchscreen. I suspect that the sluggish browser and nav map refresh may be due to the chipset being underpowered, rather than being limited by the 3G connectivity. Might I be wrong?
    Thanks!
  6. romp
    romp Member
    Seattle
    The Tegra 3 that is used in the headunit is pretty powerful chip. It's got 4 cores and can run at 1.4GHz. That's pretty fast. Although I don't know what actual speed it's running at in the car, but even at 700MHz (that'd be ~1/4 power consumption of the full speed) it still would be a pretty powerful machine. It's faster than any iPhone and iPad (although iOS devices are 64-bit, which might be beneficial for some, but certainly not all applications). It's the same chip used in Microsoft Surface and some other devices that can't be called particularly slow.
    I think the MS's browser/map performance is mostly due to the specifics of the software implementation.
    Regarding the 3G limitations: it's certainly a limiting factor, but not the single one. For example, 3G is not used when you scroll the page, but scrolling is still slow. Also, the performance doesn't change significantly when I'm on WiFi with 25Mbps connection behind it. So I'd say it's mostly software.
  7. ORB
    ORB Member
    Romp, thanks for the interesting reply! This gives me hope that these Internet apps may work better in the future, despite the current 3G limitation. I'll play with the nav app some more but using tethering to my IPad hotspot.
  8. J1mbo
    J1mbo Active Member
    UK
    Wonder if the name is a clue.. X1 :)
    Lots of relevant info in the blogs as well, especially mention of "Auto pilot" - afaik, only Tesla use this phrase, for everyone else it is "driver assistance". Pure speculation of course, would make a lot of sense for Tesla to step up from Tegra 2/3 for the X.
