D
DM231191
Guest
Thanks!Thesmokingman guide is still valid with the latest update 2022.16.2. I know because I reformatted my drive yesterday to add music space.
After my first try with the USB-A cable, I tried the USB-C cable and the speed was very high! But does this mean that the USB-A cable is not fast enough that it even can't copy a few songs? And yes I have a USB 3.0/3.1 port which I use for other devices too but never experienced this problem.Try going the nvme route. The r/w speeds are much faster to/from pc.
USB 2.0 is 480Mbps... so yea its really slow, thus use the faster cable/protocol.After my first try with the USB-A cable, I tried the USB-C cable and the speed was very high! But does this mean that the USB-A cable is not fast enough that it even can't copy a few songs? And yes I have a USB 3.0/3.1 port which I use for other devices too but never experienced this problem.
From Samsung's website the T7 is rated for USB3.2, I'd look for a USB-C cable that supports that and have your computer negotiate speed with the T7. This way the bottle neck is not the cable.After my first try with the USB-A cable, I tried the USB-C cable and the speed was very high! But does this mean that the USB-A cable is not fast enough that it even can't copy a few songs? And yes I have a USB 3.0/3.1 port which I use for other devices too but never experienced this problem.
So 3.2 is nog backwards comptabile with 3.1?From Samsung's website the T7 is rated for USB3.2, I'd look for a USB-C cable that supports that and have your computer negotiate speed with the T7. This way the bottle neck is not the cable.
3.2 is backwards compatible 3.1,3.0,2.0So 3.2 is nog backwards comptabile with 3.1?
I haven't done it myself but afaik you need to make another partition same as above and create a "BOOMBOX" folder. Add files in mp3 format with no spaces and you should be good.@thesmokingman, do you know how to add custom horn sounds? Maybe it's an option to add that to this topic?
Thanks for the info, sorry if my original post was confusing I didn't mean to imply anyone recommended the sabrent enclosure I just decided to give it a try because I liked the design. At least according to amazon comments there is confusion as to whether the sabrent has the rtl9210 or rtl9210b chipset. The linked enclosure from @thesmokingman has the rtl9210b chipset according to amazon comments. Anyways, inateck enclosure is ordered will see if it helps, hopefully it has a different chipset or there is some other secret sauce that allows it to function reliably. I'll report back if it doesn't just in case there's some weirdness with my particular car.The sabrent enclosure was never recommended, think you are confusing what a poster went with and had problems with. The enclosure I use is linked in the OP. In any case these two work below...
That's unfortunate. I would assume that it's not the enclosure but your specific drive since we have examples of the Inatek enclosure working in the field. Not all drives are compatible though, like for ex. I found the Sabrent Gen 4 drive is not compatible with the either of the enclosures I have in basic PC use, so I didn't even bother with testing it further. Do you have a different drive to test?Just wanted to post an update for anyone who may find it useful. I've now tried the Sabrent and Inateck enclosures using a 1TB SK Hynix P31 Gold nvme ssd in my 2022 Model S Plaid with Ryzen. I've confirmed with HWinfo64 that the Sabrent uses the RTL9210 chipset while the Inateck uses the RTL9210b chipset. Unfortunately neither enclosure is stable. The car will record dash cam footage for a few seconds then start corrupting footage, then recording stops for a bit before resuming once again. Cycle & repeat endlessly. Testing both enclosures with the same drive on my desktop computer under Windows 11 and Arch Linux they both perform flawlessly so sadly this is some kind of incompatibility with the car and either these external enclosures or the nvme ssd. I even found the latest firmware update for the RTL9210 chipset in the Sabrent enclosure and applied it with no change in behavior with the car.
Awesome thanks for the heads up! Sure i'll grab that one and see how it goes, not much to lose and at this point I'm pretty curious. I can return the other enclosures and got a good deal on the p31 on prime day so I would like to use it if possible.I'm running a hynix p31, but I'm using a ineo enclosure with ASM2362 chipset. No issues with AMD system. If you're dead set on the p31, you can try this active cool enclosure.
Ineo enclosure with active cooling
I used Velcro pad to attach mine. I created my own version, used 3M bonding tape on the Velcro to the glovebox. the 3M bonds stronger to the glove box than the Velcro sticky tape. Mine hasn't come off during the summer months.I have a 2022 M3 so I have to mount mine in the glovebox. I know the OP used a glovebox divider, I don’t like the look of these so was thinking of using a Velcro pad but not sure that will work in the glovebox
